Seller on amazon did not say ac or dc ledIs the LED a DC LED? Just checking to be sure.
Seller say don't need resistor just need heat sink,so sound like the seller saying there is a resistor in the led.JFTR, that LED looks very much like a standard parallel/series matrix COB without any resistors.
No, that is wrong! COB LED assemblies s require a higher voltage when compared to a normal LED. A 12V drop is not unusual (there are four white LEDs in series). Actually, white LEDs can go up to 3.6V each. This is normal LED behavior, and you should expect a large current variation without any headroom and a very small dropper resistor, when the voltage varies a little bit. The LEDs are not low quality.If you connect a 13 ohm resistor to a 12.0V battery without an LED then the current would be 923mA.
Maybe the LED has very poor quality (is cheap) so when the power supply is 11V it barely lights up and when the power supply is a fully charged 12V battery at 13V then the LED burns out.
Indeed! The OP should either raise the available voltage, or use LEDs that require less voltage.Perhaps it would be best to design according to the LED assembly's datasheet.
