Tube amp speaker out -> tap/splitter -> instrument/line level
jjredfish
Joined Apr 25, 2019
30
The goal is for the output impedance of the attenuator network (basically R1 and R2 in parallel) to be so much less than the 10 K input impedance that the output voltage does not change (much) when the output is connected to the device. The engineering rule of thumb is for the two to be at least 10:1 - for a 10 K load you want the source impedance to be less than 1 K. Not a problem in your case, so let's go to 100:1. Fix R2 at 100 ohms, and calculate R1 for the desired attenuation. Whatever R1 is, it will lower the output impedance even more, not a bad thing.
Now comes the fun part - there are several definitions of "line level": https://en.wikipedia.org/wiki/Line_level
Can you get back to the engineers with this question: "What is the value of "line level" that they design to?" An answer in dB doesn't tell us much because a dB is a ratio, and without knowing which standard or reference value they use, we cannot calculate anything. We prefer an answer in volts RMS, volts peak, or volts peak-to-peak.
The engineers confirmed: +4 dBu "Professional Audio", VRMS of 1.228, Peak amplitude VPK of 1.736.
jjredfish
Joined Apr 25, 2019
30
can this device cause ground loops?
The device plugged into the "line level" jack is designed to be used with an amplifier such as this, but it is normally placed before the input instead of after the output (as I am endeavoring to use it). Shouldn't the grounds for both devices (and their mutual compatibility) be the same potential either way it is connected?
Wolframore
Joined Jan 21, 2019
2,619
Basically you’re building a speaker level direct box. I’ve experienced ground issues when coupling amps. Sometimes it’s a shock other times noise. Many designs include a ground lift.
jjredfish
Joined Apr 25, 2019
30
Thanks for the advice. I'm pretty sure the line-level device has a ground lift switch. Any idea what the values on the two resistors should be?
Wolframore
Joined Jan 21, 2019
2,619
for 50 watts outputting to 8 ohm speaker you’re talking about 20V using ohms law. Does that help?
W= V^2/Z
jjredfish
Joined Apr 25, 2019
30
for 50 watts outputting to 8 ohm speaker you’re talking about 20V using ohms law. Does that help? W= V^2/Z
The goal is for the output impedance of the attenuator network (basically R1 and R2 in parallel) to be so much less than the 10 K input impedance that the output voltage does not change (much) when the output is connected to the device. The engineering rule of thumb is for the two to be at least 10:1 - for a 10 K load you want the source impedance to be less than 1 K. Not a problem in your case, so let's go to 100:1. Fix R2 at 100 ohms, and calculate R1 for the desired attenuation. Whatever R1 is, it will lower the output impedance even more, not a bad thing. Now comes the fun part - there are several definitions of "line level": https://en.wikipedia.org/wiki/Line_level Can you get back to the engineers with this question: "What is the value of "line level" that they design to?" An answer in dB doesn't tell us much because a dB is a ratio, and without knowing which standard or reference value they use, we cannot calculate anything. We prefer an answer in volts RMS, volts peak, or volts peak-to-peak. ak
R1 = 930 ohms? R2 = 100 ohms
And what happens if I turn the amp down some, so that I'm no longer using the full 20 watts?
Ylli
Joined Nov 13, 2015
1,092
Back of the napkin, the resistor values look OK. Most of the voltage will be dropped across the 930 ohm resistor, let's assume all of it is. P = E²/R. For the 930 ohm and an voltage of 12.65 RMS, we get a power dissipation of 12.65²/R = 0.172 watts. I'd use a 1/2 watt resistor, although a 1/4 would do. The 100 ohm will dissipate much less power, 1/4 or even 1/8 watt would be sufficient.
If you turn the amp down, the voltage at your output point will go down.
jjredfish
Joined Apr 25, 2019
30
Thanks for the reply, Ylli!
Would R1 = 93 ohms and R2 = 10 ohms (basically 1/10th of the previous numbers) work just as well? - while affecting the line-level signal, and possibly "tone", less?
I'm trying to match a line-level device with impedance = 10k ohms, and VRMS = 1.228. If I turn my amp down to use 15 watts (out of the full 20 watts) of my amp, would I still be able to use the device? Or should I measure the amp's output after I set the amp's volume control where I want it, then re-do all the math/resistors to match?
Thanks for any/all help you can offer!
Ylli
Joined Nov 13, 2015
1,092
I wouldn't go any lower on the resistor values You could probably increase them by a factor of 2 or 4 and still not have any loading problem.
Yes, the level will go down when you turn down the amplifier, and it might be best to recalculate the resistor values at the nominal listening level. But 'line level' is generally poorly defined and can vary quite a bit (I've seen 'line level' defined as anything between 0.5 and 2 volts peak).
Wolframore
Joined Jan 21, 2019
2,619
It’s true but assuming pro audio line level is +4dBu. Just start low and back off if it starts to clip. Most pro audio line level is also balanced but it should be fine.
jjredfish
Joined Apr 25, 2019
30
Thanks again for your help, Ylli. Wolframore suggested a ground lift switch. That's just a break in the ground path with a simple switch, right? Where do you think would be the best place to put it? Just before the line-out jack's "sleeve"?
jjredfish
Joined Apr 25, 2019
30
Oh, there you are! I'll just ask you... You suggested a ground lift switch. That's just a break in the ground path with a simple switch, right? Where do you think would be the best place to put it? Just before the line-out jack's "sleeve"?
By "start low and back off if it starts to clip", you mean start with resistors of R1 = 93 ohms and R2 = 10 ohms? And how do I know when it clips?
Thanks for your help, Wolframore.
Wolframore
Joined Jan 21, 2019
2,619
Can’t do it with an L-pad design. For ground lift you need isolation. I tried to bring this up early on. L-pads are better for +4 to 0 dBu drop for mic vs line input
jjredfish
Joined Apr 25, 2019
30
Gotcha, not a problem, my line-level device does have a ground lift (I checked) so I'll just use that if necessary.
When you said "start low and back off if it starts to clip", did you mean start with resistors of R1 = 93 ohms and R2 = 10 ohms? And how do I know when it clips?
Thanks
Wolframore
Joined Jan 21, 2019
2,619
Nooooo!!!.... you need to learn to use Ohm's law and calculate the current... it's V=I*R... do the power calculation... your resistors would have to be massive to do 100 ohms total resistance on the L-Pad... remember you have 20 watts coming out...
Start with your 10k : 1K divider and watch our amp level... start low and pull back if you get clipping.
jjredfish
Joined Apr 25, 2019
30
Would something like this, with an isolated socket, work for adding a ground lift to an L-pad?
