Wolframore
- Joined Jan 21, 2019
- 2,610
that's interesting... let me try ti picture it...
Can I ask where you found this? I can't see this working... there's no return path for the signal... do you want to try it? I wonder if it worked on as an example two battery powered devices....Would something like this, with an isolated socket, work for adding a ground lift to an L-pad?
It's at the bottom of this page (last post by "phatt", the attachment you can't see is the circuit I posted above)Can I ask where you found this? I can't see this working... there's no return path for the signal... do you want to try it? I wonder if it worked on as an example two battery powered devices...
Might be a good experiment
It does appear to me that they can be bypassed with the "Reactive/Resistive Switch", so they wouldn't be providing isolation in that case.They look like inductors to me. Transformer would be the preferred way of coupling audio in my book
