Trying to use a PC USB port as a power supply
TheSmouk
Joined Jun 4, 2017
7
Well, I have a really simple circuit that uses no more than a battery case (composed of 2 AA batteries), a switch, 3 resistors and 3 infrared LEDs. This is a little sketch I made: Track IR circuit sketch. By the way, the resistors are 32 Ohm 1/4 W.
The thing is that I have to change batteries every couple weeks because the LEDs start to decrease their intensity and can't be seen that well by the camera so I thought I would take out the battery case and just sold the cables to a phone charger and plug it into the USB port, but there is one thing that I am worried about and that is LEDs burning next to my face.
My question is, knowing that the USB port outputs 5V and 500mA, am I good to plug it in just like that? Or should I change the resistors by some with a higher value? I really don't know how much voltage or current I need to make the LEDs be seen well enough and that is why I am posting this.
Thank you in advance.
Alec_t
Joined Sep 17, 2013
15,168
Can't access your sketch.
If each LED has its own 32Ω current-limiting resistor then it is drawing about 30mA. So to run from a 5V supply instead of the present 3V one, you could replace each 32Ω with 100Ω (or 120Ω if you want to prolong the life of the LEDs).
If you put two of the LEDs in series as Bertus suggested then the series string would need a 32Ω resistor.
Papabravo
Joined Feb 24, 2006
22,116
According to the USB specification (2.0) what you can rely on is 5V @ 100 mA. If you want more you have to negotiate for up to 500 mA with the USB controller in the PC. I'm guessing your device has no ability to negotiate with the USB controller
WBahn
Joined Mar 31, 2012
33,348
I think IR LEDs typically have forward voltages in the 1.5 V range, give or take. If so (and note that it's a pretty significant "if so"), that means each LED is currently drawing about 40 to 50 mA on fresh batteries.
Your USB port MAY be willing to supply 500 mA no questions asked, in which case you are okay by using something in the range of 75 Ω to 82 Ω. You can probably use 100 Ω and be fine. You might want to start with 180 Ω and work your way down until you get an acceptable brightness.
Your USB port also may choose to not supply more than 100 mA unless the device negotiates for more. But if you use a charging port then you should be fine. But you are close enough to 100 mA total draw that you might be able to live with that. A 100 Ω resistor should put you close to that, but I'd recommend going with a 120 Ω to stay below the limit.
be80be
Joined Jul 5, 2008
2,399
In the USB 1.0 and 2.0 specs, a standard downstream port is capable of delivering up to 500mA (0.5A); with USB 3.0, it moves up to 900mA (0.9A). The charging downstream and dedicated charging ports provide up to 1,500mA (1.5A).Apr 19, 2017
dl324
Joined Mar 30, 2015
18,523
Well there is something very important I didn't mention and that is that I intend to use a USB 3.0 port :/
The USB 3.0 spec says you can draw up to 150mA without negotiating for more.
If you require more and can't negotiate for it, you shouldn't connect it to a USB port.
Alec_t
Joined Sep 17, 2013
15,168
Since the TS has only three LEDs the max current drawn will be 90mA (or 60mA if two LEDs are connected in series), so no negotiation is necessary.
TheSmouk
Joined Jun 4, 2017
7
Well, after being a little lazy for some weeks I decided to finally do it. I am posting this in case anyone is interested and also to say thank you to everybody who has replied and helped me do it.
I ended up using three 100 Ohm resistors and it works really well and the brightness is ideal. When I use it I check from time to time to make sure I'm not using more voltage than I should on the LEDs but since I started using the device I haven't gotten any problem. It doesn't get too hot either (even after a 3 hour session of usage).
In conclusion, thanks to everyone that helped and to the AAC community for making this a really nice place :).
