I'm trying to build this: http://www.catahoulatech.com/pdf/AmTubeTransmitterData.pdf on a breadboard. I can't figure out how the top part of the diagram connects to the bottom. For example:
- is the long wire along the bottom of the top diagram (from J1 to R3) the ground?
- in the top diagram I see a couple points marked B+ or 6V but where do they connect to the 6V/B+ wire in the lower diagram?
