Trying to derive a flip flop out from other counter outputs
Wendy
Joined Mar 24, 2008
23,857
I need to bring the 2048 output on a 4060 counter without adding a separate FF. Is their a way to derive this output using the other outputs using gates?
4060.jpg​
BobTPH
Joined Jun 5, 2013
11,665
Does it need to be 50% duty cycle?
I think anding all the lower outputs would give you the right frequency with a lower duty cycle.
Bob
Alec_t
Joined Sep 17, 2013
15,160
If you can put up with a non-uniform pulse spacing then you can use the slower frequency (4096) to chop out pulses from the higher frequency (1024), like this :
Wendy
Joined Mar 24, 2008
23,857
I like using all the lower count outputs for a diode AND gate which could then be inverted. I'll show my latest brain fart shortly on another thread. Thank you everyone for playing!
Don't see how.
Why the reluctance to use an added FF?
Trying to reduce footprint size and wiring complexity.
Ian0
Joined Aug 7, 2020
13,306
Replace the CD4060 by a CD4020 which has a Q11 output. Add two gates to the CD4020 to make the oscillator which is built into the CD4060.
Wendy
Joined Mar 24, 2008
23,857
Thank you. I needed to step back and do a rethink. Given the times are grossly rounded off (as they were in my old concept). Here is a 4040 approach. The top 4 outputs will count down in a binary display (inverted).
Reference 2.png​
LesJones
Joined Jan 8, 2017
4,544
I normally use Farnell. I keep a list of items that I am low on stock until the order will qualify for free postage.
The TS if they chose this option would have to choose one that they was capable of programming.
Les.
Ian0
Joined Aug 7, 2020
13,306
Les.
They’ve got none of the ones I use - quoting delivery dates of April 2022!
LesJones
Joined Jan 8, 2017
4,544
I've not ordered anything from them since November 2019.
I was thinking of PIC12F1840 or ATtiny13A. They have the PIC in stock but not the ATtiny.
If the TS was interested in that approach I probably would have suggested the ATtiny as the programming hardware required is cheaper.
Les.
Wendy
Joined Mar 24, 2008
23,857
Lets keep it on topic, guys. My first project for a µC would be a 4 digit counter, but I don't use them ATM.
Lack of expertise.
Wendy
Joined Mar 24, 2008
23,857
To finish off this thread I'll post the solution (which I'll never use).
Solved.jpg​
