Trying to reduce footprint size and wiring complexity.Don't see how.
Why the reluctance to use an added FF?
Trying to use gates to generate the signal will likely result in more wiring and complexity than adding one FF package.Trying to reduce footprint size and wiring complexity.
Thank you. I needed to step back and do a rethink. Given the times are grossly rounded off (as they were in my old concept). Here is a 4040 approach. The top 4 outputs will count down in a binary display (inverted).Replace the CD4060 by a CD4020 which has a Q11 output. Add two gates to the CD4020 to make the oscillator which is built into the CD4060.
Where would you buy a microcontroller at the moment?Using an 8 pin microcontroller would would reduce the size and component count.
Les.
They’ve got none of the ones I use - quoting delivery dates of April 2022!I normally use Farnell. I keep a list of items that I am low on stock until the order will qualify for free postage.
The TS if they chose this option would have to choose one that they was capable of programming.
Les.
