Truth Table -> 3 output -> boolean expression -> circuit (DIGITAL LOGIC AND COMPUTER HARDWARE)
judyfinny
Joined Feb 26, 2016
8
So I created a boolean expression based on the truth table. There are 3 output and three 4 input in the truth table. I have always seen one output and I know how to create a circuit with the boolean expression. But for the lab, I got three expression and we have to use that to create only NAND gate circuit. I am not sure how to use three different expression and make a NAND gate circuit. so these are the expression QQ: (y = AC + BCD + ABD) ; PP: ( y = A'B'C + A'CD' + AB'C' + AC'D' + A'BC'D + ABCD); CC (y = B'D + BD').
The question is to design realizations of the circuit using 1. only NAND gates 2. only NOR gates 3. AND, OR, and NOT gates.
I don't need an answer for this. But if you could explain how to use three different boolean expression to create one big NAND only circuit, that would be great. Thank you.
RBR1317
Joined Nov 13, 2010
715
You should apply DeMorgan's Theorem to convince yourself that a NAND gate is also an OR gate with negated inputs. That makes the NAND gate especially useful for building Sum-of-Products logical expressions (AB+CD). Likewise, a NOR gate is also an AND gate with negated inputs, and is useful for building Product-of-Sums logical expressions (A+B)(C+D). Note that negation of an output can be cancelled by a negated input.
My usual design technique is to draw the logical expression as a circuit diagram using AND/OR/NOT gates, then add pairs of inversion circles to the ends of a signal line, or move an inversion circle from an output to an input (or the reverse) until the gate types are all-NAND or whatever is necessary. After a while doing this you will just 'see' an OR gate with negated inputs as a NAND gate without having to redraw it.
33,068
Take the circuits for each output and implement them using only NAND gates.
Done.
Now, there may well be some overlap between the logic equations that would allow you to share parts of it and reduce the gate count, but nothing indicates that this is expected or required, so simply treat them as three different circuits from start to finish.
33,068
Am I understanding correctly that you have not simplified the Boolean equations, yet?
I don't think you can infer anything about that one way or the other.
From his original post:
Cleaning this up just a bit, it should be: I have four inputs and three outputs, so I created boolean expressions based on the truth tables. There are three outputs, and thus there are three 4-input truth tables.
shteii01
Joined Feb 19, 2010
4,644
That is true.
Back when I was getting my education, I might have had table like this:
ABCD|Q1|Q2|Q3
It is one table... but in reality it is three tables like you are saying.
judyfinny
Joined Feb 26, 2016
8
You said 3 outputs.
I did not understand the part about the number of inputs. How many inputs are there?
Sorry, I just noticed the error. What I meant to say was there are 4 inputs and 3 outputs. (A,B,C and D are input and QQ PP CC are output). Sorry about that
shteii01
Joined Feb 19, 2010
4,644
Next step is to simplify the Boolean equations. Have you been taught any techniques to simplify them?
Like RBR said, you can just do three circuits and run all three circuits to the same ABCD inputs. Might take a bit of space.
33,068
Here is the truth table. This will make sense if I post the truth table i guess
There is absolutely no need for a 3MB file to convey three 4-input truth tables. This is just sheer laziness on your part. You can EASILY get that down to about 1% of that size with just a couple minutes effort. Instead, you expect members, many of whom have slow internet connections, to download a file that is literally a hundred times bigger than needed.
shteii01
Joined Feb 19, 2010
4,644
I blame cell phones. The effing things don't have any software to change image file size.
33,068
Then perhaps they should find a suitable platform with basic capabilities instead of imposing 100x the workload on everyone else just because it is more convenient for them.
judyfinny
Joined Feb 26, 2016
8
Thank you :) I will do that.
judyfinny
Joined Feb 26, 2016
8
I am sorry. I didn't give much thought to that.
