Under the right circumstances, it would be; as noted in the app note, his circuit is only good for 300 mVrms to 10 Vrms. Not a very big range.Thanks for clarifying. So the most viable way to measure RMS is through accurate temperature measurement then?
I've used the AD536 chip you mentioned earlier, with pretty good results; that would probably be my first choice for general-purpose RMS measurements.What about extremely low power waveforms?
I've used this method, too, and it worked well for me in one application where I needed a 10Hz-3KHz frequency response; but the higher you need to go in frequency, the higher the sample rate you need to use along with a DSP with greater and greater horsepower.What other methods are there, other than ADC and then integration?
