Memory fails again.
It was a Cossor, not Marconi, but there were often more than one manufacturer for Nato spec equipment.
The discussion about signal level is interesting because this meter has an old style switched input attenuator from 30 mV to 300 Volts FSd.
This brings up the interesting point because the attenuator (although compensated) will be affected by signal frequency, so no matter how perfect the RMS measurement system is, if the input chain changes it there will be an effect in the reading. That is the measurement is only the RMS of the signal presented to the sensing circuit, which is not necessarily the same as the input.
Secondly note that RMS does not necessarily mean linear scaled.
Finally note good old fashioned practice of stating things like mod history and equipemnt weight on the front.
