Hey,
I soldered 7 exact same high side switches (followed this explanation) (for a 7 segment display, I bought common cathode ones, stupidly) onto a board like this. 6 of them work pretty much as expected (11.8V output when the NPN base is 5V, about 0.6 when it's logic LOW/connected to GND), but one doesn't work properly. No matter what I connect the NPN base to, the output voltage seems to gradually climb towards 1V and then drop again. I think I had an accidental connection between my 12V and the PNP collector. I fixed that and carefully checked for more accidental connections, and then swapped out both transistors without success. I even checked that the resistors are still working as expected. What could still be broken here?
Thanks in advance,
Ben
Thanks in advance,
Ben
