Troubleshooting Pioneer S-W700 subwoofer
fordman76
Joined Mar 30, 2022
84
Brightness at test lamp very low. Can barely see filament.
Q7511
Base = .867 vdc
Collector = - .027 vdc
Emitter =1.01 vdc
Q7513
Base = - 0.00 vdc
Collector = - 2.288 vdc
Emitter = - 50.8 vdc
Q7512
Base = .634 vdc
Emitter = -1.04 vdc
Q7514
Base = - 50.9 vdc
35,321
Measure the DC voltage at the bridge rectifier D1201:
pin-1 with respect to GND
pin-4 with respect to GND
It would appear that the bridge rectifier is bad.
fordman76
Joined Mar 30, 2022
84
I must be doing something wrong. I looked for your post, even logging out and back in several times. Just saw your post with time of 2:38 pm.
I measured the D1201
pin-1 with respect to GND =52.4 vdc
pin-4 with respect to GND =-52.2 vdc
Looks like the rectifier ok?
35,321
Try to do some signal tracing. (I am going to round voltages to nearest integer.)
You should have these:
+B1 = 52V
-B1 = -52V
Q7511 Emitter = 52V
Q7512 Emitter = 52V
Q7513 Emitter = -52V
Q7514 Emitter = -52V
fordman76
Joined Mar 30, 2022
84
Just found it. Bad solder joint where I lifted the B1+ jumper yesterday. Resoldered it.
Rechecked all emitter readings and B1 + and - readings as follows:
B1- = - 50 v
B1+ = 51 v
Q7511 Emitter = 50 V
Q7512 Emitter = 51 V
Q7513 Emitter = -50V
Q7514 Emitter = -50V
35,321
Good. Now do the voltage measurements at the power transistor terminals, B, C, E.
(Show all digits as reported on the DMM.)
This is the standard power on test you need to repeat.
LEFT === RIGHT
Q7511 = Q7512
Q7513 = Q7514
Report the brightness of the test lamp.
fordman76
Joined Mar 30, 2022
84
Very dim filament on bulb.
Q7511
Base = ..805
Collector = .404 v
Emitter = 49.0v
Q7513
Base = - .003 v
Collector = .045 v
Emitter = - 49.1 v
Q7512
Base = .742 v
Collector = .431 v
Emitter = 49.2 v
Q7514
Base = - 49.3
Collector = .437 v
Emitter = - 49.2 v
35,321
The voltages at the base are not right. We now have to look at the circuits driving the base.
We have to measure the voltages at the driver transistors. There are 4 for each channel for a total of 8.
LEFT === RIGHT
Q7503 = Q7504
Q7505 = Q7506
Q7507 = Q7508
Q7509 = Q7510
fordman76
Joined Mar 30, 2022
84
I found Q7503, Q7504, Q7509 and Q7510 on the board. Q7505, Q7506, Q7507 and Q7508 on foil side of board and were SOT-23s
LEFT RIGHT
Q7503 = Q7504
B= .865 v B=.823 v
C= -.776 v C=.133 v
E= -.896 v E=.129 v
Q7505 = Q7506
B= .891 v B=.180 v
C= .175 v C=.182 v
E= .160 v E=.000v
Q7507 = Q7508
B= .874 v B=-.892 v
C= -.124 v C=-.135 v
E= -.112 v E=-.124 v
Q7509 = Q7510
B= -.804 v B=-.813 v
C= -.112 v C=.002 v
E= -.121 v E=-.135 v
Collector and emitter readings on Q7503 were not stable bouncing around between -. 6 and -.9 v.
35,321
Unplug the unit from AC mains.
Measure the following resistances in-circuit.
Measure with test leads in both directions.
LEFT === RIGHT
R7547 = R7548
R7549 = R7550
The expected value is 220Ω for all four.
fordman76
Joined Mar 30, 2022
84
These are really tiny on the foil side of the board. Just touched the negative lead of my multimeter to one lead and got a spark. Not sure what;s working now. These resistors are really smali ! I think my meter leads are even to big for the tiny spaces. Called my self being real careful. Well so much for that.
What is the possibility of finding a board like this somewhere? I would know where to start my search, since this unit is 90's vintage.
35,321
The resistors are SMD packages. Most meter probes would be fine enough for probing.
If you think that you have reached your limits then I will leave it up to you to decide when it is time to call it quits.
fordman76
Joined Mar 30, 2022
84
I'll let you know tomorrow. Let me think on it tonight. Thanks again for your help and patience. If decide to throw in the towel, I will try to find a repair facility somewhere locally here in southeast Michigan.
fordman76
Joined Mar 30, 2022
84
Was I supposed to have discharged capacitors as in a previous step before I started to measure resistance of the 4 resistors? I just unplugged the power from the 120 v source.
I guess I am not really ready to throw in the towel if you are willing to continue .Your time is important, and if you feel I have reached my experience limit, I can understand.
I have enjoyed working with you and getting the benefit of your knowledge. As I said before I am no EE and have a lot to learn. Thanks again for your time and patience.
