IC2 is suppose to make a PWM signal to the servo.At 5V, the outputs of the 4017 can probably source about a mA. So the smallest value would be around 5k. You could go lower since you don't need the outputs to maintain a valid logic level.
I missed that you have the second timer wired as an astable. A one shot made more sense, so that's how I read it. What is your intent for the second timer.
You showed it as being connected between pins 5 and 6.
