The board is MC2100E REV C and the symptoms are the same as the OP says. LED solid ON, motor tested fine, blue pin on HD2 shows increasing voltage with increasing speed from console (i don't have a proper PWM meter or oscilloscope, but get an increasing 0-0.7V reading against ground as i increase the speed on the console). Incline control works.
The U1 opto is ok, passing signal to pin 2 of the microprocessor. But nothing comes out at pin 8. Does this mean the microprocessor is faulty? Wouldn't the led be off if the micro was dead? Maybe there are more inputs to the micro that I need to check?
