- Joined Jul 18, 2013
- 30,839
Quote:.
Have you spotted any infomation from the TS to say what his mains voltage is or what country he is in ?
Les
"I live in Canada and the standard voltage is 120V."
Les
Canada I believe running 120 volts at 60 Hz.Have you spotted any infomation from the TS to say what his mains voltage is or what country he is in ?
I agree Les.Thanks Max & Ron, So it probably is a 120 volt DC but I would like to complete the schematic to be sure before telling the TS to order the relay. (Or to go for the SSR solution)
Les.
I briefly looked into voltage divider. I'm a complete rookie but do I just add a pair of resistors to divide the voltages like the image shown below? If yes, where do I add them?Yes, as to things like Contact Form , this link gives a good overview. Problems can arise when the actual pin out on for example, a board mounted relay are not the same. This leaves the end user crawling through endless data sheets looking at dimensions and what the actual pin out is. My reference to form when I mentioned form, fit and function was to finding a relay which would fit in the space provided. That or start getting creative.
I was surprised the system manufacturer did not simply have one off the shelf.
The existing relay appears to have a 110/120 VDC coil. If I could not find a suitable mechanical replacement I would likely just shove an SSR in and be happy. 90 to 240 VAC output SSRs are pretty common. I would settle for the common 3 - 32 Volt DC control voltage and simply divide the now incoming coil voltage to a usable control voltage. Not like the control voltage requires any current and a simple 4:1 or 5:1 divider should work fine. That's likely how I would try to go about it.
Ron
I apologize for the bad image quality of the etch board. Hopefully the following is clearer as I shone a light behind it.Thanks Max & Ron, So it probably is a 120 volt DC but I would like to complete the schematic to be sure before telling the TS to order the relay. (Or to go for the SSR solution)
Les.
Got to find the saw first but I will post it when it's done.@Jolteon if the relay is shot cut the top off, it may disclose a few things if shot you have nothing to lose.
Do you know where they are located/shipped from?Contact Bailey
http://www.baileyproducts.com/files/86694322.pdf
Phone number is on the bottom of PDF
I think they are in Texas. Most manufacturers do no ship direct to end customers unless you buy a bunch so ask who their distributors are near your city (or a US distributor that ships to Canada.Do you know where they are located/shipped from?
Yes, X1 is connected to an auto/on/off switch. At the beginning, I thought this was just a general electronics forum but realized thereafter, it is geared towards electrical engineering which I have no experience with. When I googled "electronic circuit forum", this appeared as the top search and I registered, hoping to find the exact relay to order. After contacting the manufacturer (out of stock on relays currently), I do not want to waste your time or anyone's else and decided to place a special order on the alternative relay suggested by the employee at the local electronics store. On the other hand, I am interested in the voltage divider but I have no experience with that as well. I do not mind learning but I feel terrible as you will have to explain how to work out the relay coil versions, etc. This community is great and I really appreciate your help and others. Thank you.Here is the schematic.
This shows that my assumption that the relay coil is 120 volts is wrong. There is effectivly a 5K resistor in series with the relay coil. we will have to work out which relay coil version in series with with 5 K matches about 120 volts DC. I don't know what connects to the connector X1 but a think a switch will connect it's centre pin to the mosfet drain.
Les.
I see, thanks.I think they are in Texas. Most manufacturers do no ship direct to end customers unless you buy a bunch so ask who their distributors are near your city (or a US distributor that ships to Canada.
Maybe I am doing it wrong? I set the multimeter at 200 ohms (lowest) and the reading is OL for pins 2-3.Have you checked that the pinout dimensions on the data sheet from the link that Ron provided in post#3 ? After looking at the coil resistances of the relays in the data sheet it looked like it could be the 110/120 volt one or the 48 volt one. (With 5K in series with either of them would require about 150 volts. ) It is reasonable to expect this voltage across C2 as it will be somewhere between the RMS and peak value of the input voltage. Working out the dissipation in the series 5K resistor with the 48 volt coil gave a value of about 2 watts. As the two 10 K resistors look to be about 1/2 watt rating it suggests that is more likely to be the 110/120 volt relay.
COULD YOU PLEASE AT LEAST TRY TO MEASURE THE COIL RESISTANCE ON YOU RELAY.
Les
This thread is about 6 months old. What transformer are you talking about? The one shown in post #51? You would do better to start a new thread and post clearly your objective.is anyone able to give me a suitable part number or specs for the transformer?
Hello Jolteon! I have the same trouble as you with my Ivac, I've you find a solution to your faulty relay?Yes, X1 is connected to an auto/on/off switch. At the beginning, I thought this was just a general electronics forum but realized thereafter, it is geared towards electrical engineering which I have no experience with. When I googled "electronic circuit forum", this appeared as the top search and I registered, hoping to find the exact relay to order. After contacting the manufacturer (out of stock on relays currently), I do not want to waste your time or anyone's else and decided to place a special order on the alternative relay suggested by the employee at the local electronics store. On the other hand, I am interested in the voltage divider but I have no experience with that as well. I do not mind learning but I feel terrible as you will have to explain how to work out the relay coil versions, etc. This community is great and I really appreciate your help and others. Thank you.
Has anyone come up with a solution yet? I have the same iVac control with a dead power relay and am attempting to source a replacement. I know this is an old thread but the issue I have is exactly the same.Hello Jolteon! I have the same trouble as you with my Ivac, I've you find a solution to your faulty relay?
