Trouble analyzing circuit
giv know
Joined Jan 10, 2015
2
I have the following problems understanding the above circuit:
  • I understand the part where the optocoupler activates transistor T3 acting as a relay driver. I also understand that this would activate relay RL1. But how does relay RL(a) get activated to N/O?
  • Also, when the relay is in the N/C position, how does power from the 12V SMF battery get to the output?
  • The NAND gate N1 has both inputs at the same value. When the ac mains is working, wouldn't the NAND give 0 as output where as it should actually be giving 1?
Note: This circuit can be found at http://bestengineeringprojects.com/electronics-projects/advance-mini-ups/ along with an explanation. I can not make sense of the explainaion, hence this post.
giv know
Joined Jan 10, 2015
2
The labeled diagram is quite helpful. Thanks Eric!
Could you confirm if its safe to conclude that once RL1 gets energized, all 4 of its contact sets switch to N/O.
ericgibbs
Joined Jan 29, 2010
21,440
hi giv,
Yes, the relay has 4 pole change over, sets of contacts.
N/O = Normally Open, N/C = Normally Closed, this is when the relay is not energised == Off.
So all the N/O contacts are closed, when the relay is energised.
E
