Triac vs bjt
Khader987
Joined Apr 16, 2017
9
No. BJTs and TRIACs are two completely different things.
Yes i know bro but can i apply ac across the collecto
No, you can use a Thyristor and bridge rectifier instead, but why bother.
i mean can i apply ac at its gate and across the collector and emitter , logicaly it will work at the positive half cycle but at the negative one it doesnt so it may work as a half wave rectifier knowing that i can use a diode for that but just wondering is it correct ?
Khader987
Joined Apr 16, 2017
9
Here is a relationship with Mosfet and BJT.
i mean can i apply ac at its gate and across the collector and emitter ,logicaly it will work at the positive half cycle but at the negative one it doesnt so it may work as a half wave rectifier knowing that i can use a diode for that but just wondering is it correct ?
38,504
With no base current (open-base), an NPN transistor will block the positive half-cycle (if within its voltage rating) but will conduct on the negative half-cycle when the base-emitter junction breaks down at about 5V or so.
If any significant current flows under this reverse voltage condition, the transistor will likely be zapped.
Note that a BJT doesn't have a gate, it has a base.
Khader987
Joined Apr 16, 2017
9
So
I tried to simulate it as u said positive cycle is blocked when no current at the base but when the base is biased both negative and positive pass and it acts like a triac and i used a resistive load of 10k connected to the collector so no significant current passes it is just about few milli amps ... what about that isit correct ... thank you
38,504
The simulator likely doesn't properly simulate the reverse breakdown of the base-emitter junction.
It does not act like a triac which stays on, even with no gate current, after it is triggered on.
DickCappels
Joined Aug 21, 2008
10,661
Both a triac and an SCR will remain on once triggered until the zero crossing. The main difference is that an SCR can only conduct when the anode is positive with respect to the cathode. A triac can conduct regardless of the polarity of the applied voltage.
This circuit uses an NPN to switch AC. If you can get a triac that is probably a better solutioin.
Khader987
Joined Apr 16, 2017
9
thank you mr. dick
MrAl
Joined Jun 17, 2014
13,704
Transistors also have a problem when they turn off when there is some inductance in the circuit. There could be a kickback that causes a high spike to appear. It's harder to deal with in an AC circuit. Triac's do not have this problem because theoretically the current must be zero when they turn off. You can trick a triac with a transistor, but then you're back to the transistor spike problem.
Khader987
Joined Apr 16, 2017
9
thank you mral
