Triac stops functioning properly when used with an inverter.
idrbur
Joined Jan 11, 2018
70
I asked before about triac not working with induction fan.
After few experiments i found out that triac stops functioning properly after everytime there is a power cut and the fan supply switches from mains to inverter.
Can anyone suggest why is this happening and what can i do to prevent this. 36d2f5b8-90cc-4fbe-9c4d-b940ae5f843a.png
What's happening to triac is that it probably starts leaking some current.
In off condition the fan continues to spin very slowly and make loud humming noise.
But when i start controlling its speed with moc3021 and microcontroller it works perfectly.
Any suggestion is appreciated.
Thankyou.
Ian0
Joined Aug 7, 2020
13,132
The output of a good inverter is indistinguishable from the mains. Sounds like you don’t have a good inverter.
Ramussons
Joined May 3, 2013
1,568
Your invertor may not be sine wave. It's output may be Distorted Square wave.
You can try a solution putting a 2.2 K resistor between the Gate and MT2 (the lower terminal) to prevent dv/dt triggering of the triac.
Ian0
Joined Aug 7, 2020
13,132
The opto triac is much more susceptible to dV/dt triggering than the main triac. Try the circuit in section 2.4 of ST’s application note AN5114, that should remove the high dV/dt if the inverter is one of the so-called “modified” sine wave types,
idrbur
Joined Jan 11, 2018
70
I will try the the circuit suggest by Ian0, hopefully it will work.
And R16 works perfectly even with such high value i decided to use it just to be safe.
AlbertHall
Joined Jun 4, 2014
12,625
Values for this circuit are shown in section 3.2
Ian0
Joined Aug 7, 2020
13,132
A triac with to little trigger current is much more likely to fail than one with plenty, due to slow turn on,
100k gives 3.25mA at mains peak, less at every other trigger angle. The BT136 is only guaranteed to trigger at 5mA,
I use 100Ω, not 100k, designed to give as much trigger current as the opto device can withstand.
idrbur
Joined Jan 11, 2018
70
The circuit didn't work well for me.
The fan just started rotating at full speed.
I will try replacing the R16 with 100Ω resistor.
Thanks for your suggestions.
