Triac Equivalent - soldering station
mike69
Joined Dec 22, 2012
83
I built the attached schematic and I wanted to find if the TL431 oscillates, using an oscilloscope.
I tested by connecting the ground probe to the 220uF capacitor ground and the detachable hook to TL431 catode.
The measurements were made when the soldering iron was connected into the circuit.
1. Can you please explain if there are oscillations in the screenshots ?
2. It is normal to be multiple sine waves in the same screenshot, as it is in MAP002 and MAP003 ?
ebeowulf17
Joined Aug 12, 2014
3,307
I'll start with a disclaimer that I don't have hands-on experience with a TL341 or similar devices. However, since you have no other responses yet, I'll give you my best guesses.
1) There's a lot of variety in those screen shots. I'm not sure if that's oscillation, or just induced noise creeping in or slipping through.
2) Depending on your scope settings, and whether this was with single trigger or normal trigger mode, could be normal. See:
https://www.eevblog.com/forum/testgear/multiple-traces-after-stop-button-is-pressed/
semsette
Joined Apr 5, 2020
5
I designed an almost identical circuit that avoids the complexity of isolating the trigger circuit. I powered the soldering iron from the un-smoothed, rectified 24 volts ac. That way I could switch it with a power MOS FET. The diode shown in the diagram connected to R8 is a red LED.
I used an inexpensive 2.3 to 30 volt digital meter to indicate the temperature. It works very well.
why the diagram shows the Source connected to the ground while in component schematic the Source is connected to the iron?
KeithWalker
Joined Jul 10, 2017
3,628
You are correct. Thank you for pointing it out. The Source should be connected to ground. I don't know how I missed that one in the documentation. I guess I connected it correctly on the one I built because it still works great.
semsette
Joined Apr 5, 2020
5
Thanks for the reply. Can you also confirm that the mosfet used is irfz40?
KeithWalker
Joined Jul 10, 2017
3,628
It looks like a really good project. I'm already working on the circuit. Just two things:
-what type of transformer do you suggest me to use?
-what kind of iron handle can i use? (heating element A1321-A1322.....)
Regards.
Ed.
I used an old Radioshack transformer with 12.6-0-12.6V 2A secondary. I ordered the parts for the Iron from Aliexpress.
Handle:
https://www.aliexpress.com/item/32835896063.html?spm=a2g0s.9042311.0.0.27424c4dkG15vZ
Tip bushing:
https://www.aliexpress.com/item/32724325226.html?spm=a2g0s.9042311.0.0.27424c4d10urTx
Element:
https://www.aliexpress.com/item/32691098329.html?spm=a2g0s.9042311.0.0.27424c4d1wtGnV
Connectors:
https://www.aliexpress.com/item/32866277697.html?spm=a2g0s.9042311.0.0.27424c4d10urTx
