KeithWalker
- Joined Jul 10, 2017
- 3,625
So what do you think might happen?The ground of the soldering station, which is connected at the rectifier ground (rectifier minus) is not connected to the mains (power) ground.
Yes, it will. It will not be dangerous to the operator but if the circuit ground is connected to any metal parts of the station, e.g. the case, the circuit will be damaged if the soldering iron tip comes in contact with them.I think that a potential difference will appear between the station ground and the power ground, because the grounds are not connected together.
What do you want to protect from what?Hello,
I am using the soldering station from this topic with good results, but I am wondering if there exists a better schematic, which has protection for the soldering iron.
Can someone please show me a schematic which has protection for soldering iron ?
Thank you in advance.
Try reducing the value of R1. Start with 2.2Kohms. That should let you adjust the range.I was thinking about protecting the soldering iron from overheat, if the circuit of the soldering station is damaged. But I will leave this and I will guide my attention to the schematic from this site: http://electronics.vlzqz.com/analog-pid-soldering-station.html
I built today the schematic, and I do not know how to make it work correctly. The problem is that momentary I do not have the oscilloscope in my workshop, probably it will take a few months until I will get it back.
The problem is that I got maximum 14.4mV on the thermocouple, but I need 20mV in order to have a good adjustment range. I tried to turn the 2 trimmers in both directions, but I am getting maximum 14.4mV on the thermocouple. What I am missing or what should I do to make it work correctly ?
LE: I am using the same soldering iron as it is on that webpage (Gordak, with K type thermocouple).
Where exactly are you measuring?I made the following modifications:
1. Replaced R1 by 2k2
2. Replaced R6 by 33k
3. RV1 rotated at about half of the course
4. RV2 rotated at about 11.2k between the GND and wiper.
I am getting now about 20.2mV maximum.
Are the modifications correct ?
LE: Initially it was working fine, now the voltage from the thermocouple is varying between 11 and 13mV (with the 5k pot at about half), initially it was varying between 13.3 and 13.5mV.
The construction article stated: "Since the soldering iron handle thermocouple is a type K (I think) it produces voltages between 0mV and 19mV in the range of 0 to 450 (which was the range that was useful for this project)."I made the following modifications:
There are a number of inconsistancies between the component designators on the schematic and the pcb. You have two chopices:I wanted to try another soldering station schematic, but I found that there is a mismatch between the image of the PCB and the schematic. That mismatch is located near R14. On the pcb R14 is connected to pin 5, but in the schematic is not connected to pin 5.
What should I do ?
Please have a look at the attached document ...
Which one is correct between the schematic and the pcb ?There are a number of inconsistancies between the component designators on the schematic and the pcb. You have two chopices:
You can spend a lot of time correcting the errors or you can find another controller.
You could build the one I made. It works very well. I designed a pcb for it but I made mine on prototypr circuit board using the pcb layout as a guide.
I would assume that the schematic is correct.Which one is correct between the schematic and the pcb ?
That looks like an interesting, and perfectly viable circuit, but there are a few things I think are potentially misleading there:I was thinking about protecting the soldering iron from overheat, if the circuit of the soldering station is damaged. But I will leave this and I will guide my attention to the schematic from this site: http://electronics.vlzqz.com/analog-pid-soldering-station.html
If you enjoy a challenge, reverse engineer their pcb layout into a second schematic, then compare the two schematics to see which one makes more sense and build yours accordingly.I wanted to try another soldering station schematic, but I found that there is a mismatch between the image of the PCB and the schematic. That mismatch is located near R14. On the pcb R14 is connected to pin 5, but in the schematic is not connected to pin 5.
What should I do ?
I don't know. What does IC1B do? Where did you get the schematic from? Was there no description of it's function?Does the attached schematic has a power off mode for the soldering iron if the thermocouple voltage rise above a set value, for example above 20mV ?
