studiot,
At that time, I thought that EMF was synonymous with voltage. I was presenting what I thought was a clearer, more direct, and more descriptive way to think about voltage.When you started this thread you clearly stated that you know what EMF is and that you were posting to help others understand.
Yes, I could not and still do not understand what that term means, although I automatically translate it mentally into the word "voltage" and consider it to be a distinction without a difference.You also decried the use of the term EMF
I did not think the meaning of the name "EMF' was relevant to the discussion.We have to wait until post#47 to discover that you don't actually understand EMF at all.
That is too much tail chasing.
I already did in responses #13 and #47.If you were to say EMF is confusingly named and ask for explanation, I would agree with you and try to give a suitable account of what it is and how it came to be so named.
You would be correct.I do not know what your technical background is or where in the world you are, but your command of English is such that I guess it to be your first language.
You probably had a very good knowledge of Euclidian geometry.When I took my first level secondary school exams I thought I knew everthing about geometry.
There lots of different geometries and applications.What a shock was in store when I started co-ordinate geometry.
So by my second level exams I again thought I knew all about geometry and now, vectors and scalars.
You must have known that you would learn new and wonderful things from those courses. Otherwise you would not have bothered to enroll in them.What a shock when I started my applied maths degree and started linear algebra, vector and scalar fields, Poisson's equation, the Navier-Stokes equations.......
As are we all.After 35 years applying maths in engineering in several parts of the world , postgraduate qualifications and membership of an august Engineering Institution -
I am still learning.
See response #13. Keep it below the tensor analysis level.So tell us what you don't understand and what level you would like the answer pitched at and we will try to help, don't just decry what others have said.
Which get discussed and corrected.Otherwise this thread contains apparantly authoritative mis-statements and misconceptions by several posters ...
I don't. As long as it stays civil. That would be sweeping it under the rug. It will just show up elsewhere under a different venue. Besides, this discussion is interesting and informative. Ratchand so I think, reluctantly, should be closed.
