treadmill motor accelleration
victoriaredgreen
Joined Jul 21, 2017
5
I have built what amounts to a go kart using an inverter and a treadmill motor and controler the acceleration time on the controller is not adjustable. I have a solid electro mechanical background but once a component has more than two legs I get lost. The motor is about 2 1/2 hp and uses an MC-60 controller. it runs okay but the lag in acceleration and deceleration makes everything difficult. especially throttling back and putting on the brakes. On better motor controllers there is a pot or variable resistor to change the acceleration. I assume that there is a fixed resistor that can either be removed or replaced with a different value and get instant voltage change.
Does anyone have experience with this and can help me?
Eric in Victoria BC Canada
MaxHeadRoom
Joined Jul 18, 2013
30,658
On the MC-60 R19 can be removed to defeat having to take the pot to zero to start.
I have managed to defeat the accel decel time, you may be better looking at a KB controller for complete control.
Max.
MaxHeadRoom
Joined Jul 18, 2013
30,658
If you search here I have previously posted reverse engineered drawings of the MC-60.
Some of the resistors are tailored for different motor etc. And removed or cur as needed.
Max.
