Hi.
I am new to the forum, but have had a look around trying to solve my problem.
I was using the treadmill yesterday, happily running along and increased the speed, it proceeded to turn off.
Switched it back on and off- nothing.
Went to the manual, checked the reset and then changed the fuse in the plug.
Switched on and the house fuse blew.
Disconnected from the electrics and began to try and isolate the issue.
Unplugged the lead and turned power on. - All OK
Power goes to adaptor block, AC?
Then to PCB and then to motor.
Disconnected power to motor and power stays on, am able to press the buttons on the console, but obviously motor does not turn.
Interestingly incline doesn't work. But unsure if motor needs connecting fro this to happen. (I wasn't using incline when running.)
I can connect 12v via a car battery to the motor and it works without problems, spinning freely.
What is my next option??
Thanks for having a read.
The model is a Domyos TC-7.
