Treadmill - blowing house fuse
MihaiBrB
Joined Mar 19, 2022
48
Logical trouble shooting is required,, it is extremely rare to have a bad motor.
Generally the reverse engineered schematic is sufficient.
There is the motor Mosfet/BJT circuit with associated driver and also the SCR ramp up of the DC voltage.
Do not trouble shoot with motor attached, use a dummy load.
the mosfet / igbt was replace with original one and also the mosfet/drive..the circuit was checked and some had blown smd resistenaces near the igbt gate that i have also changed.
the SCR circuit that ramps dc voltage to caps its pointless..you keep saying the SCR.the Scr / Thyristor just acts like a relay..thats all.it loads the caps with dc from the bridge rectifier
MihaiBrB
Joined Mar 19, 2022
48
i will remake the motor and i am pretty sure thats the nr 1 cause for this boards to go out
MihaiBrB
Joined Mar 19, 2022
48
Wrong in this case, the SCR is used to ramp up the DC slowly, if it is shorted, the full voltage is across the motor at start.
Actually wrong.Thyristors get a fix signal input at the gate,they dont controll the flow of the curent.when gate voltage is prezent at the gate it triggers conductivity from the anode to the chatode.further voltage at gate after current flow is made changes nothing.thyristor continues to conduct until voltage of the circuit drops under a certain treshold
MihaiBrB
Joined Mar 19, 2022
48
so its just a
so its just a silicon switch !
MaxHeadRoom
Joined Jul 18, 2013
30,824
What I intended to imply is that the SCR is switched from the start of the ripple with a gradual ramp up to maximum from the MicroProc.
IOW, it is a phase angle controlled ramp-up of the DC.
