Transistor Switch giving funny readings
Mashly
Joined Apr 4, 2014
33
Hi Guys,
Probably going to be really silly question here.
I am trying to make a transistor switch with a voltage divider to get a output prportionally lower than the input when the base is pulsed.
I am using trying to get no more than 5V when using a 12V source (testing the voltage of a battery using an arduino).
I have chosen R1 as 1K, R2 as 2K and Rb as 4K. It seems to work when I turn the base on (I get around 5V output at 15V input). But when I turn the base off and measure the voltage across the capacitor I am still seeing the 15V input? Why could this be?
Thanks for any help in advance.
Mash
Edit: with a BC108 transistor.
Mashly
Joined Apr 4, 2014
33
Don't worry I think I have solved it.
The volt meter is measuring voltage drop, so when the no voltage on the base, the drop between the collector and ground is 15V.
Does this sound correct?
Alec_t
Joined Sep 17, 2013
14,314
If your circuit is intended to work as I'm guessing, then I think you'll need a 2-transistor solution; something like this.
Edit:
If transistor leakage current is significant then a respective ~33k resistor between base and emitter of each transistor could be added.
Mashly
Joined Apr 4, 2014
33
Sorry if I am being a bit stupid, but could you elaborate on the need for the two transistor circuit?
I am looking to get the voltage of a battery with an Arduino so I can send it using a radio module I have. I will pulse the transistor every minute (or when needed) to get the voltage then send it via the radio link.
Mashly
Joined Apr 4, 2014
33
Hi, this is the way I was thinking of doing it, with just the one transistor. It is not properly set up yet as I am still trying to learn spice, but you should get the idea.
21,225
In your circuit the Vout will be at 12V when the transistor is off. Ohms law requires the voltage drop across a resistor to be 0 when there is no current flowing. It this what you intended? 12V on a digital input would be ahhh...bad bad thing.
Mashly
Joined Apr 4, 2014
33
I think I see what is happening now. The NPN is shorting the base to ground when pulsed which turns the PNP on. There is no voltage present over the voltage divider now when the PNP is turned off.
Mashly
Joined Apr 4, 2014
33
Thanks got it working, Your value of 100K was a bit high for the Transistor I was using but replaced it with a 4K and it works fine.
Can anyone tell me if this will be temperature stable or if I can do anything to help with this?
Thanks again.
Mash
ScottWang
Joined Aug 23, 2012
7,400
Edit:
The c of Q1 need to pull high, otherwise, when the input(Vpulse) is low, then the c of Q1 will be floating, it maybe has a chance to causing the c of Q2 oscillating.
