Transistor in Active and saturation region
mishra87
Joined Jan 17, 2016
1,063
What is basic calculation for transistor to work in Active and saturation region. :
Lets take BC547 transistor in calculation :
Calculation with example :
dl324
Joined Mar 30, 2015
18,438
For BC547, Ib = Ic/20 for saturation mode operation.
For active mode operation, B-E junction forward biased, C-B junction reverse biased.
mishra87
Joined Jan 17, 2016
1,063
I did not get still why does Ib = Ic/20 ???
Hfe = 110 - 800 for bc547
Could you explain a bit more about Active region.
please consider some calculation ????
bertus
Joined Apr 5, 2008
22,974
We use the 1/10 to 1/20 of the collector current as base current to force the transistor in saturation.
Bertus
dl324
Joined Mar 30, 2015
18,438
The datasheet assumes beta=20 for saturation mode:
The 110-800 value is for VCE=5V and Ic=2mA. When you're operating in saturation mode, VCE is going to be 0.6V max.
You just bias the transistor so that the junctions are biased as I indicated.
mishra87
Joined Jan 17, 2016
1,063
Examples :
Vcc = 5V
Vled = 1.6V
Vce(sat) = .25V
Ic= 20mA
hfe= 100
Vb = 3.3V
In saturation : Rc = (5-1.6-0.25)/20mA = 157.5 ohm
so ib= (20/100 ) = 200uA , lets say ib>200uA
Rb= (3.3-0.7)/200uA = 13K
Hope above calculation is correct for saturation region
Now : what is active region and how to do calculation for it.
38,609
The active region is when the transistor is used as an AC or DC amplifier.
In this active region, where the collector-emitter voltage is more than a volt, the collector current equals the base current times the transistor current gain (β or Hfe from the data sheet, which can vary significantly from unit to unit).
The saturation region is when the transistor is used as an on-off switch.
In this saturation region, the base current is increased to 5-10% (forced Beta of 10 to 20) of the maximum collector current, so that the transistor is fully saturated, with a minimum collector-emitter voltage (turned completely on as a switch).
The other state is with no base current. where the transistor does not conduct (turned completely off as a switch).
Make sense?
Bordodynov
Joined May 20, 2015
3,431
The approach to the separation of the active and saturated modes of the transistor may be different. As a criterion can be output resistance. Or the degree of saturation.
yashnit
Joined Apr 23, 2019
You can conclude the operation of a transistor if it is saturated or not by doing actual measurement. Monitor the collector-emitter voltage of your circuit with a DMM. If the reading is below 0.3V, the transistor is at saturation. Transistors are having saturation voltage range from 0.7V and below but for a circuit designed for hard saturation, the VCE will be lower. Figure below is the setup on how to measure the collector-emitter voltage of a transistor in circuit. Read More
dl324
Joined Mar 30, 2015
18,438
Examples :
Vcc = 5V
Vled = 1.6V
Vce(sat) = .25V
Ic= 20mA
hfe= 100
Vb = 3.3V
Your calculations aren't correct. Try building the circuit to see if it works.
As I mentioned earlier, the datasheet indicates a beta of 20 for saturation mode. That changes the required base current.
\( \small I_B = I_C/20 = 1mA
R_B = \frac{3.3V-0.7V}{1mA} = 2600\Omega \)
WBahn
Joined Mar 31, 2012
33,023
Examples :
Vcc = 5V
Vled = 1.6V
Vce(sat) = .25V
Ic= 20mA
hfe= 100
Vb = 3.3V
This is meaningless without the circuit it applies to. Don't make us guess -- engineering is not about guessing.
mishra87
Joined Jan 17, 2016
1,063
Hey WBahn,
I am not guessing anything.
I have done calculation for a practical circuit and then i was asking my doubts through forum.
I hope analog people can understand my intentions.
Regards,
mishra87
Joined Jan 17, 2016
1,063
Make sense?
Thanks !!!
Much valuable reply.
mishra87
Joined Jan 17, 2016
1,063
Marketed well to your website. !!!
WBahn
Joined Mar 31, 2012
33,023
Hey WBahn,
Regards,
You aren't guessing because you know what the schematic is for the circuit you are talking about.
You are forcing US to guess because you won't share schematic with us. So we don't know whether you have a base resistor, or an emitter resistor, or a collector resistor, or what the emitter supply voltage is. We have to guess at all of that stuff. Why do you want to force the people that you are trying to get to help you to guess at what the circuit is that you are working with?
