How does middle layer of a transistor get a charge in order to get reverse biased or forward biased accordingly?
Doubtician
Joined Mar 19, 2022
18
I dont know much about electronics.While studying about transistors,i had a doubt about the middle layer.If the emitter and middle layer becomes forward biased, and collector and middle layer becomes reverse biased,how does middle layer have both the charge in order to get reverse and forward biased at the same time?Pardon me if i understood it the wrong way.
Ian0
Joined Aug 7, 2020
13,317
It's not the layers that are biassed, it's the junctions between them.
If base voltage is greater than emitter voltage, the base-emitter junction is forward biassed. If collector voltage is greater than base voltage then the base-collector junction is reverse biassed.
Delta Prime
Joined Nov 15, 2019
1,311
Hello there,welcome to AAC!
:)I need to see exactly what you are seeing or studying can you post a link a picture or just draw it on a piece of paper.
dl324
Joined Mar 30, 2015
18,524
Welcome to AAC!
A picture would be helpful. Your use of charge is confusing.
A bipolar junction transistor has two junctions. In active mode, the BE junction is forward biased and the CB is reverse biased.
Papabravo
Joined Feb 24, 2006
22,116
It is the battery or voltage sources that create the potential differences across the junctions. The base is more positive than the emitter, so that junction is forward biased. The collector is similarly more positive than the base, so the base collector junction is reverse biased.
\( V_b>V_e\implies V_{be}>0\implies \text{Forward Biased} \)
\( V_b < V_{c}\implies V_{bc}<0\implies \text{Reverse Biased} \)
Papabravo
Joined Feb 24, 2006
22,116
So,in a PN junction diode, the junction is biased and not the diode as whole ,right?
What happens at a pn-junction is a bit more complicated than a simple model can convey. The simple explanation is that the external potential (aka voltage) changes the impediments to current flow in such a way that a semi-conductor becomes an actual conductor.
