Transistor Checker 200610
allenpitts
Joined Feb 26, 2011
182
Hello AAC Forum,
This is pretty basic but it is written: 'The recognition of ignorance is the beginning of knowledge.'
I used to put my projects together and power it up and cross my fingers. Now I try to
test as I build to find mistakes in sub systems.
So I was checking the connections to the transistors and for the heck of it the probes
were placed at the connections to the base and the collector which I expected to have negative continuity.
I was surprised when the LED came on. I guess I thought that the function of the base is to turn on the connection
between the emitter and the collector. I did not realize, and it looks like the symbol implies, that there is a connection
between the base and the collector.
So a way of checking the transistors was imaged. I believe the Transistor Checker will work as shown in the schematic
except the plan was to put a small 1.5 volt battery at the base to allow the transistor to complete the connection to ground.
The question is how to ground the small battery. Go back to ground on the nine volt source? Or how about
putting a voltage dividing resistor between the nine volt source and the base to knock it down to a couple of volts and obviate the
second energy source?
Thanks.
Allen
dl324
Joined Mar 30, 2015
18,326
A BJT consists of 2 PN junctions. A transistor is turned on by forward biasing the base-emitter junction. This biases the transistor into either the active or saturation region.
If you reverse the emitter and collector, you can turn the transistor on by forward biasing the base-collector junction. A device operated in this mode (inverted) will have very little current gain, but the collector-emitter saturation voltage will be very low (for the right transistor geometry).
Using a 9V transistor checker is risky. If you reverse bias the base-emitter junction enough to break it down, transistor beta will be permanently impaired.
I use a continuity checker that consists of 2AA batteries and a flashlight bulb. Forward biasing a PN junction will cause the bulb to light dimly. My most recent was purchased from Home Depot.
Audioguru again
Joined Oct 21, 2019
6,826
The base-emitter voltage of all silicon transistors is 0.6V for a low current or 1V for a very high current.
Applying 1.5V without having a series current-limiting resistor Will Blow It Up!
