Transient response of semicinductor switch
38,576
I'm not sure if stripline will be possible, so I guess microstrip is more probable. Although, I must admit, I haven't really thought about interconnecting possibilities yet.
Well, if you are concerned about transient effects then you need to since that will have a large effect on them.
The switch itself is only a small part of that
paw1
Joined Jan 13, 2015
32
You are probably right, but is there any possibility of simulating these interconnection techniques? I may be wrong, but I doubt it's possible in LTSpice IV, which I use. I also have Simulink, but it's a bit cryptic to me to be honest.
38,576
LTspice will work if you know the parasitics of the board. You just add them to the schematic. The trick, of course, is determining that from the layout.
Some of the advanced PCB layout software do calculate the parasitics from the layout but that software tends to be expensive.
You might check one of these references for some clues as to how to do the layout.
MikeML
5,444
The device will switch a 6GHz RF signal, however the switching rate is orders of magnitude slower than that. If used as a Transmit/Receive switch, for example, the switching rate might be measured in seconds.
The layout issues are basically creating a transmission line up to each port.
38,576
The data sheet states the switching times are less than 10ns.
paw1
Joined Jan 13, 2015
32
Really helpful.
Thanks.
