Transformer Power supply dilemma
fiatuno
Joined Jan 28, 2011
47
Hi members, I am designing a power supply with an LM338 and I have got a transformer that from 240vac gives an output of around 18V ac and a max current of 3.5 A. The power supply I need to build is 12V dc and 5A max current and for this I am using the LM338. I am asking as this regulator I have only one and I can't find easily in here so I cannot afford any errors. Is it possible to get the Maximum current of 5A from this transformer please, since it has alot of extra voltage which is 18V ac please. Thanks in advance.
Regards,
Fiat Uno
35,177
You may be able to do it if the transformer has a center tap,
but a lot depends on the actual transformer.
You are just a bit short on voltage or current.
fiatuno
Joined Jan 28, 2011
47
My main problem is that I cannot simulate it neither on proteus and i need to try it by myself on the hardware itself, and cannot afford any errors. If I am not mistaken the transformer I have is an 18v 3.5A with a 5A 250V Fast blow fuse.From my knowledge on electronics, if I reduce the voltage I should get a bigger current. What I need to keep in mind is there will be a voltage drop in the LM338 and I think this will be the main problem as it will reduce my voltage available to get the 5A. I don't know if my reasoning is good. Thanks in advance for your help
fiatuno
Joined Jan 28, 2011
47
To tell you the truth, that information is what I have found on the web on a post one made on the same power supply. I am a bit scared of ruining it if I open it. Or is it safe enough as I am used to open other electronics but never power supplies and I am very afraid of ruining it as it was expensive when I had bought it for my surround system. How do you see if it is center tapped please? it is sort of like the below link the one I am using:
http://www.vdott.com/crms/bigpic/stock/vdott/600_699/6174_1.jpg
35,177
Hah! That is not a transformer.
That is a switched mode power supply.
There is no way you can increase the output from 3.5A to 5A.
It is always a good thing to tell the truth in the first place.
fiatuno
Joined Jan 28, 2011
47
Thanks very much for your help, then. Just for the sake of learning, how can I recognise if it is a switched mode power supply or a transformer if it is giving an ac voltage on the output please. Thanks in advance
fiatuno
Joined Jan 28, 2011
47
and please what type of transformer would I need to use the LM338 to get the desired 12V 5A. Thanks in advance, regards
fiatuno
