Transfer Function
vmm
Joined Jun 23, 2021
5
photo_2021-06-23_17-33-06.jpg I need to find the transfer function of this RL circuit. I've tried to figure it out but I think something went wrong. Any help would be apprecciated!
vmm
Joined Jun 23, 2021
5
The problem is that when I plot the transfer function I get the following Bode diagramsBode_plot.JPG
so the circuit is a high-pass filter but the position of the R and L components is different from the classic RL high-pass filter.
Am I wrong?
So far everything looks good. What do you expect to get?
ericgibbs
Joined Jan 29, 2010
21,542
hi vmm,
Have you considered that the R2 value maybe the internal resistance of the Inductor.?
What do you consider is wrong with the Bode Plot.?
E
vmm
Joined Jun 23, 2021
5
Thanks for the tip! I didn't think about that! So can I assume that this is an ordinary RL high-pass filter and calculate the cutoff frequency, right?
hi vmm,
What do consider is wrong with the Bode Plot.?
E
ericgibbs
Joined Jan 29, 2010
21,542
hi,
If the Inductor has a known resistance, then the impedance of the total R & L should be included, as the Vout signal is across this total impedance, not just the inductor impedance.
E
What are the given values of R1 , R2 and L.??
ericgibbs
Joined Jan 29, 2010
21,542
hi,
Compare these two plots, one with Inductor resistance and one with no inductor resistance.
The Transfer functions must be different for the two examples.???
vmm
Joined Jun 23, 2021
5
Yes, the transfer function is different (as matter of fact I've got a different function) but both are high pass filter because both pass all frequencies above the cuttoff frequency. Am I right?
hi,
EView attachment 242021
Jony130
Joined Feb 17, 2009
5,598
Just by looking at your schematic and transfer function, we can see that DC gain is:
K_dc = R2/(R1 + R2)
And we will have one Zero and one Pole. And from what I see you decided to use R1= R2 = 10 Ω and L = 1H and this is why you have a DC gain at -6dB (0.5 V/V) and Fc =√(Fz*Fp) = 2.25Hz (due to the fact that the zero and pole are no well spread apart from each other).
MrAl
Joined Jun 17, 2014
13,776
Just a quick note....
For a single RL or RC series circuit possibly also with resistive load...
When the inductor is in series with the output the response will be low pass.
When the inductor is in parallel with the output the response will be high pass.
Since the capacitor is the dual of the inductor, the opposite is true:
When the cap is in series with the output the response is high pass, and
when the cap is in parallel with the output the response will be low pass.
The main reason for this is because of the way the impedance changes for each element as the frequency changes. You should probably graph that also so you get a feel for what is happening.
You can use these ideas to get a sanity check of your computed response. it's more qualitative than quantitative but helps as a quick check.
