Transfer Function with Current
The Electrician
Joined Oct 9, 2007
2,986
For a circuit as simple as this, either mesh or nodal analysis will work. The only impossibility arises when using the mesh method with a non-planar network, which this is not.
You can even solve this network just by doing a few series-parallel transformations; you can almost do it in your head.
All that said, usually when you have only current sources driving a network, the nodal method is most straightforward. If voltage sources alone are present, then the mesh or loop method is good. Otherwise, you may have to use concepts like supernodes or supermeshes.
