Transfer function of a cascaded op-amp circuit
xdarkbee
Joined Dec 9, 2022
11
I have doubts with the following circuit, I have already obtained the transfer function to the circuit but only with resistors, now they have put a capacitor and I don't know how to proceed
LvW
Joined Jun 13, 2013
2,035
The calculation procedure is as before when you replace the feedback resistor of the 1st opamp with the capacitive impedance Zc=1/jwC.
However, under real conditions the circuit will not work because of resistive positive feedback. There will be no stable DC operating point and the circuit will go into saturation.
xdarkbee
Joined Dec 9, 2022
11
The circuit would be fed back with a PID controller that makes it seek its stabilization, do you think that it works?
LvW
Joined Jun 13, 2013
2,035
No, I don`t think so. A PID controller will influence the dynamic behaviour of a circuit but it cannot fix a dc operating point.
In any case - you must avoid DC feedback with two inversions within the loop.
As a working example: The classical state variable filter (universal filter) consists of an integrator stage plus an inverting amplifier (as in your case) plus an additional integrating stage within one loop.
xdarkbee
Joined Dec 9, 2022
11
Before I asked how to convert my plant into a circuit, since I was going to test the PID controller in a physical circuit and they gave me that circuit that has an unstable pole, so how do you recommend I model my function which is 1/ s - 2 in a circuit functional?
Papabravo
Joined Feb 24, 2006
22,111
A voltage-controlled voltage source whose output grows exponentially.
