Transducer freq response
ricn
Joined Sep 6, 2017
Does anyone know how to determine the shortest duration event a displacement sensor can detect if the sensor has a freq response spec of 100Hz @ -3dB?
wayneh
Joined Sep 9, 2010
18,164
Nope. Two things are missing, the loss of dB that can be tolerated before the signal looks like noise, and how the signal rolls off with frequency. With only the given data, I’d have to say anything less than 10ms is approaching dicey detection.
38,814
If the transducer has a first-order rolloff than the risetime for a step change would be about 1.6ms (to .632 of the final value).
5 time-constants (8ms) would give a response to within 1% of the final value.
But as noted, that's only if the transducer has a first-order rolloff.
