I do not understand the code given in GitHub link https://github.com/glidernet/ogn-tracker/blob/master/gps.c It seems code have been written for GPS and rtos.
Can anyone tell what the code suppose to do? What's the role of rtos in the code?
C:
#include "gps.h"
#include <stdio.h>
#include <string.h>
#include <stm32l1xx.h>
#include <FreeRTOS.h>
#include <FreeRTOS_CLI.h>
#include <task.h>
#include <semphr.h>
#include <timers.h>
#include "usart.h"
#include "messages.h"
#include "cir_buf.h"
#include "console.h"
#include "options.h"
#include "spirit1.h"
#include "ogn_lib.h"
#include "display.h"
#include "timer_const.h"
/* -------- constants -------- */
/* http://support.maestro-wireless.com/knowledgebase.php?article=6 */
static const char * const pcResetNMEA = "$PSRF101,-2686727,-4304282,3851642,75000,95629,1684,12,4*24\r\n";
static const char * const pcShutDownNMEA = "$PSRF117,16*0B\r\n";
/* -------- defines ---------- */
/* - GPS ON_OFF mappings - */
#define GPS_ON_OFF_PIN GPIO_Pin_4
#define GPS_ON_OFF_PORT GPIOB
#define GPS_ON_OFF_CLK RCC_AHBPeriph_GPIOB
/* -------- variables -------- */
/* circular buffer for NMEA messages */
cir_buf_str* nmea_buffer;
xQueueHandle gps_que;
static TimerHandle_t xGPSValidTimer;
static TimerHandle_t xGPSWdgTimer;
static uint8_t GPS_fix_found;
static uint8_t debug_mode;
/* -------- functions -------- */
* @brief Send new GPS fix status to display task.
* @param New fix state
* @retval None
void GPS_Send_Disp_Status(display_opcode_types msg_type)
task_message display_msg;
xQueueHandle* disp_task_queue = Get_DisplayQue();
if (disp_task_queue)
/* Start CW */
display_msg.msg_data = 0;
display_msg.msg_len = 0;
display_msg.msg_opcode = msg_type;
display_msg.src_id = GPS_USART_SRC_ID;
xQueueSend(*disp_task_queue, &display_msg, portMAX_DELAY);
* @brief GPS fix timeout callback.
* @brief Callback is called when there is no valid fix for 2 secs.
* @param Timer handle
* @retval None
void vGPSValidTimerCallback(TimerHandle_t pxTimer)
GPS_fix_found = 0;
GPS_Send_Disp_Status(DISP_GPS_NO_FIX);
Console_Send("GPS fix lost.\r\n",0);
* @brief GPS data timeout callback.
* @brief there is no data from GPS for OPT_GPS_WDG_TIME seconds.
* @retval None
void vGPSWdgTimerCallback(TimerHandle_t pxTimer)
Console_Send("!! GPS watchdog reset (use gps_wdg_time 0 to disable) !!\r\n", 1);
NVIC_SystemReset();
* @brief Function called whenever valid GPS position is found.
* @param None
* @retval None
void GPS_Valid_Position(void)
xTimerStart(xGPSValidTimer, portMAX_DELAY);
if (!GPS_fix_found) /* detect only once */
GPS_Send_Disp_Status(DISP_GPS_FIX);
Console_Send("GPS fix found.\r\n",0);
GPS_fix_found = 1;
* @brief Functions parses received NMEA string.
* @param string address, string length
* @retval None
uint32_t GPS_GetPosition(char *Output) { return OGN_GetPosition(Output); }
void Handle_NMEA_String(const char* str, uint8_t len)
OGN_Parse_res_t ret_value;
static char DebugStr[120];
ret_value = OGN_Parse_NMEA(str, len);
if (debug_mode)
sprintf(DebugStr, "NMEA:%6.6s[%2d] => %d\r\n", str, len, (int)ret_value);
Console_Send(DebugStr, 0);
if (ret_value == OGN_PARSE_POS_VALID_CURRENT)
GPS_Valid_Position();
return;
* @brief GPS Cold Reset.
* @param None
* @retval None
void GPS_Reset(void)
USART3_Send((uint8_t*)pcResetNMEA, strlen(pcResetNMEA));
void GPS_Off(void)
if (!*(uint8_t *)GetOption(OPT_GPS_ALW_ON))
USART3_Send((uint8_t*)pcShutDownNMEA, strlen(pcShutDownNMEA));
vTaskDelay(200);
void GPS_On(void)
GPS_Off();
GPIO_SetBits(GPS_ON_OFF_PORT, GPS_ON_OFF_PIN);
vTaskDelay(200);
GPIO_ResetBits(GPS_ON_OFF_PORT, GPS_ON_OFF_PIN);
void GPS_Debug_on(void)
debug_mode = 1;
* @brief Configures the GPS Task Peripherals.
* @param None
* @retval None
void GPS_Config(void)
GPIO_InitTypeDef GPIO_InitStructure;
debug_mode = 0;
uint32_t* gps_speed = (uint32_t*)GetOption(OPT_GPS_SPEED);
uint16_t* wdg_time = (uint16_t*)GetOption(OPT_GPS_WDG_TIME);
if (gps_speed)
USART3_Config(*gps_speed);
/* GPS validity timer */
xGPSValidTimer = xTimerCreate(
"GPSTimer",
/* The timer period in ticks. */
2500,
/* The timer will stop when expire. */
pdFALSE,
/* unique id */
( void * )GPS_VALID_TIMER,
/* Each timer calls the same callback when it expires. */
/* GPS watchdog timer */
xGPSWdgTimer = xTimerCreate(
"GPSWsgTimer",
*wdg_time*1000*portTICK_PERIOD_MS,
pdFALSE,
/* unique id */
( void * )GPS_WDG_TIMER,
/* GPS ON/OFF pin configuration */
RCC_AHBPeriphClockCmd(GPS_ON_OFF_CLK, ENABLE);
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
GPIO_InitStructure.GPIO_Pin = GPS_ON_OFF_PIN;
GPIO_Init(GPS_ON_OFF_PORT, &GPIO_InitStructure);
* @brief GPS Task.
* @param None
* @retval None
void vTaskGPS(void* pvParameters)
task_message msg;
OGN_Init();
OGN_SetAcftID(*(uint32_t*)GetOption(OPT_ACFT_ID));
/* Allocate data buffer */
nmea_buffer = init_cir_buf(CIR_BUF_NMEA);
/* Send cir. buf. handle for USART3 driver & console */
USART3_SetBuf(nmea_buffer);
Console_SetNMEABuf(nmea_buffer);
/* Create queue for GPS task messages received */
gps_que = xQueueCreate(10, sizeof(task_message));
/* Inform USART driver about receiving queue */
USART3_SetQue(&gps_que);
/* Inform Console about receiving queue */
Console_SetGPSQue(&gps_que);
/* Enable USART when everything is set */
USART_Cmd(USART3, ENABLE);
/* Wait 700ms for GPS to stabilize after power on */
vTaskDelay(700);
/* Perform GPS on sequence */
GPS_On();
/* Check GPS fix status */
GPS_fix_found = 0;
if (xGPSWdgTimer) xTimerStart(xGPSWdgTimer, portMAX_DELAY);
for(;;)
xQueueReceive(gps_que, &msg, portMAX_DELAY);
switch (msg.src_id)
case GPS_USART_SRC_ID:
/* Received NMEA sentence from real GPS */
char* nmea_str= (char*)msg.msg_data;
if (*(uint8_t*)GetOption(OPT_GPSDUMP))
/* Send received NMEA sentence to console (with blocking) */
Console_Send(nmea_str, 1);
if (msg.msg_len >= 6)
/* A2235-H possible bug: observed (very rarely) lack of CRC (*12) at the end of NMEA sentence */
/* cold reset triggered to get out of the state */
if ((nmea_str[0] == '$') && (nmea_str[msg.msg_len-5] != '*'))
Console_Send("GPS bug detected - GPS cold reset should fix this.\r\nIf not - reconnect battery.\r\n", 1);
GPS_Reset();
Handle_NMEA_String(nmea_str, msg.msg_len);
break;
case CONSOLE_USART_SRC_ID:
/* Received NMEA sentence from console */
Handle_NMEA_String((char*)msg.msg_data, msg.msg_len);
break;
default:
break;
