Total Impedance in this Circuit
cheyenne
Joined Dec 6, 2007
48
I was asked to find the total impedance in this circuit and I got the answer:
= 17 Angle -47.13. Is it possible for someone to check this for me to see if i've done it correctly, thanks.
Edit: I also got the voltage across the inductor as being = 8.32 V Angle 33.7.
The Electrician
Joined Oct 9, 2007
2,986
I get a total impedance of 16.87 angle -46.8476
Are you using a calculator that can do complex arithmetic? You seem to have some slight errors in your arithmetic.
For the voltage across the inductor, I get 4.932 angle 80.5377
I calculated it by finding the equivalent impedance of the right branch and the middle branch in parallel (I got 11.5385 - j2.3077), and then calculating the voltage across those two branches by treating their parallel equivalent plus the -j10 as a voltage divider ( I got 5.6757 + j4.0541 volts). Then, knowing the voltage across the middle branch, calculate the current through that branch by dividing the voltage across the branch (5.6757 + j4.0541 volts) by the impedance of the branch (15 + j15); the current is .3243 - j.0541. Finally, knowing the current in the middle branch, multiply the current by the impedance of the inductor (0 + j15) to get the voltage across the inductor (.8108 + j4.8649) and convert to polar coordinates.
cheyenne
Joined Dec 6, 2007
48
Hi, thanks. It was my poor rounding that caused the error in the first part and thanks for showing me how to find the voltage across the inductor.
