Toshiba Multivibrator TC4538BP
cstroh
Joined Jan 16, 2019
111
Has anyone worked with this 16 pin IC TC4539BP from Toshiba and can anybody tell me what the input pins 1 and 2 labeled 1T1 and 1T2 do? The data sheet talks about everything but. There is a block picture showing these inputs but no description as to what they do.
cstroh
Joined Jan 16, 2019
111
Sorry about that, the 9 keys is to close the 8 key. The identifier should have read TC4538BP. I will check against the CD4538. Thanks to you both and sorry about the misprint.
Alec_t
Joined Sep 17, 2013
15,117
From the left side of the Logic Diagram in the Toshiba TC4538 datasheet it is clear that T1 and T2 are the connection points for the timing resistor and capacitor. Pins 1 and 2 are for channel 1; pins 14 and 15 are for channel 2.
