Tordial transformer wiring?
bunker
Joined Nov 25, 2019
6
My first time using a tordial transformer. the transformer is supposed to be a 48 volt center tapped secondary. I have the primary wired this way, blue and violet and brown and gray. I have the secondary wired as red and orange as the center tap and black and yellow each at 24 vac.If this is correct,why am I getting 27.7 volts at the secondary. do I have it wired wrong or is this just the nature of the beast? I posted an image of the transformer info,hope this is enough information. Thanks , Brian
LesJones
Joined Jan 8, 2017
4,511
The voltage will drop to about it's rated voltage when it is supplying it's rated current. When you rectify it's output with a capacitor on the DC side of the bridge rectifier the peak voltage will be 1.414 times the RMS AC voltage at the input to the bridge with no load. As there is no load the capacitor will remain at the peak value.
Les.
bunker
Joined Nov 25, 2019
6
Les.
so my wiring is correct, thanks for the info
MaxHeadRoom
Joined Jul 18, 2013
30,661
If the voltage is too high with rectifier and smoothing cap, Toroidals are usually fairly easy to modify by removing a few turns (typically 2T/volt).
Just be aware that the secondaries are probably wound bi-filar.
Max.
bunker
Joined Nov 25, 2019
6
Max.
tha tha thanks, I am old enough to remember Max.
