im using an old micronta test probe. 55 timer pin 3 output is high and the led indicator is steady on. all vcc & gnd pins check ok. u2 pin 14 is H and all pin 9's are L
forgot to ask, does it matter that i dont have a cmos timer?
New Channel Selector from old Lockout. P ch. FET's can go on Channel Selector or with individual channels, dealer's choice. All 3 555's are reset at power-up or by pressing Reset SW at any time. C4 1uF to 20 uF.
When one channel is selected, other 2 are held at reset.
D, 4011, NAND gate is used as invertor as you have some, my pref. would be 4049 as alternate.View attachment 106075
Do I like the new idea- No because it requires many changes & description is a bit fuzzy.
In your spare time you might make a loop of 3, 555s, each driving 1 to 40 parallel LEDs with resistors. Using low side drive there would be 2 LEDs on, 1 off, giving the appearance of movement, like blood flowing- or water?
I'm changing the name of the Lock Out circuit to Channel Selector with its 3 start switches, Channel A, red for 20 s. of red throbbing LEDs, Channel B, blue for 20 s. of rippling stream, & Channel C, green , 20 s. of single LED chaser, labeling as desired.View attachment 106030
Stream # 12 modified to Stream # 13, to drop internal 20 s. timer as Channel Selector already supplies one. Clearing the SRs is now done at turn on.
U-2 had to be moved to be part of Channel Selector, leaving only one invertor required, U-F1, which might be changed to a NPN transistor, eliminating the 4011.
Here is the schematic for a traveling blank LED string, might also be known as Marque Lights?
Travel speed is about 10 cm / sec. set by R2-4-6 & 1 uF Cs. Sub. with 1 meg. pots to vary speed.
R 10, 1 k will give red LEDs about 10 mA, adjust as desired. R's marked * are 10 k.
Similar circuit, Olympic rapid fire training aid by MarkAB, next page.View attachment 106275
