N Thread Starter Nnasser Joined Dec 21, 2019 2 Dec 21, 2019 #1 Hello everyone Please can someone tell me if this IC ( TOP209P ) is the same AS this one ( TYNY275PN) Is it doing the same functions? Can I replace the TOP209P with TYNY275PN ? THANK YOU SO MUCH
bertus Joined Apr 5, 2008 21,148 Dec 21, 2019 #2 Hello, Both are switching regulator controllers. The TNY has an enable/Undervoltage pin. Bertus Attachments TNY275.pdf 1.6 MB Views: 0 TOP209.pdf 447.2 KB Views: 0
N Thread Starter Nnasser Joined Dec 21, 2019 2 Dec 21, 2019 #3 bertus said: Hello, Both are switching regulator controllers. The TNY has an enable/Undervoltage pin. Bertus Click to expand... Thank you so much Bertus So can i replace it safely?
bertus Joined Apr 5, 2008 21,148 Dec 21, 2019 #4 Hello, Compare the characteristics. I would say no as direct replacement. Bertus
S Sobhanjahaniparast Joined Dec 13, 2019 9 Dec 21, 2019 #5 They are in two different categories. I don't recommend.
