toggle switch dpst wiring
joe dirt
Joined Nov 21, 2017
hi there everyone im new at this forum so not sure if im in the right place.
i oder a 4pst swtich 8 pins on off and some momentary 3 pins switch. now my projet is to use the on off switch as a main swithc 12 volt to give power to my momentary switch. now i order the wront one i wanted a 12 pins switch so the middle pin have the 12 volt from the battery and then wire exterieur pin to the momentary switch. can i still use the 8 pin if their no pin in the middle of the swtich( there hole like i can add pin to it).
something like this
https://www.google.ca/search?rlz=1C1CHBF_enCA761CA761&biw=1455&bih=655&tbm=isch&sa=1&ei=8o0UWt3cCYukjwSYo4XIDA&q=toggle+switch+8+pin&oq=toggle+switch+8+pin&gs_l=psy-ab.3..0i8i30k1.230391.235704.0.235900.27.19.2.3.4.0.213.1919.0j13j1.14.0....0...1c.1.64.psy-ab..8.18.1769...0j0i67k1j0i30k1j0i13k1j0i13i30k1.0.yTXX4EVxLFU#imgrc=0mJDhmMsp5BUWM:
joe dirt
Joined Nov 21, 2017
If you mean you want to convert 4 pole single throw, to 4 pole double throw, then no you cannot add a pin.
Max.
ok so can i wired my 8 pin on (none) off switch to give 12 volts to my monentary switches(2 switches) and a push button and when its off no power to the momentary swtich on push button
