Today news from Fermilab (USA) can herald serious problems in Particle Physis
Delta Prime
Joined Nov 15, 2019
1,311
Hello there!
even the hint of a new fundamental particle or force that interacts differently with these different types of particles should and is wonderful progress. Sadly it will not change the laws of physics but create new ones with better jokes to go along with them
upand_at_them
Joined May 15, 2010
939
This is what I was satirizing:
https://en.wikipedia.org/wiki/Faster-than-light_neutrino_anomaly
...Later the team reported two flaws in their equipment set-up that had caused errors far outside their original confidence interval: a fiber optic cable attached improperly, which caused the apparently faster-than-light measurements, and a clock oscillator ticking too fast.
"D'oh!...I hate when that happens."
upand_at_them
Joined May 15, 2010
939
That's why theoretical physicists hate experimentalists. The purpose of experiments is to CONFIRM theories, not upset the applecart!
How many theoretical physicists have you polled? Many experiments are pure (not applied) science, intended to just find things out. They were smashing particles together before they knew what would come out. I think the quark model was late in the game and was proposed *because* the experiments were showing other (unpredicted) stuff. Not unreasonable to have a theory and then go test it....Why wouldn't you? But applecart upsetting certainly isn't anathema to science.
today news regarding experiment conducted in Fermilab ( Muon g-2 experiment) seems to be very interesting:
https://news.fnal.gov/2021/04/first...xperiment-strengthen-evidence-of-new-physics/
Best regards
Move along, nothing to see here. :eek:
It's not a shocker that the standard model is incomplete or flat wrong in some cases. New physics are a misnomer because no matter the refinement eventually found it will still be compatible with SM to a very high degree on everything that matters in our daily lives unless you lived microseconds from the Big Bang.
https://sitn.hms.harvard.edu/flash/2018/frustrating-search-new-physics/
Papabravo
Joined Feb 24, 2006
22,078
I was one for a time, but that's another story. It was Murry Gell-Mann and George Zweig that independently came up with the quark hypothesis in 1964 and confirmed by experiment four years later. The Nobel quickly followed.
Delta Prime
Joined Nov 15, 2019
1,311
Yes! a misnomer but it paints a picture in the mind let's see here picture this!
"Atom" literally means something that can't be split.
Dark matter isn’t dark. Dark things absorb light. Dark matter is transparent
Centrifugal forces - this non-debate makes me tired just thinking about it!
The word "finite" is used all the time to mean "non-zero". And it pains me to see mathematicians wrap their head around that one. Its why I carry a pocket full of smelling salts :p
https://theconversation.com/proof-o...rding-to-a-new-theoretical-calculation-157829
My team’s theoretical prediction is different from the original theory and matches both the old experimental evidence and the new Fermilab data. If our calculation is correct, it resolves the discrepancy between theory and experiment and would suggest that there is not an undiscovered force of nature.
Our result was published in the journal Nature on April 7, 2021, the same day as the new experimental results.
BobTPH
Joined Jun 5, 2013
11,501
Yes, I had already seen this. Multiple 4 sigma results have melted away in the past, and this one is only at 3 sigma. Not time to panic or rejoice yet.
Bob
https://phys.org/news/2026-04-particle-thought-physics-reveals.html
Particle thought to break physics followed rules all along, research reveals
In a paper published in the journal Nature, a team led by a Penn State researcher describes one of the most precise calculations ever performed in particle physics, showing that the Standard Model—the theory describing the known building blocks of matter—still holds.
"There were many calculations in the last 60 years or so, and as they got more and more precise they all pointed toward a discrepancy and a new interaction that would upend known laws of physics," said Zoltan Fodor, distinguished professor of physics at Penn State and lead author of the study.
"We applied a new method to calculate this discrepancy quantity, and we showed that it's not there. This new interaction we hoped for simply is not there. The old interactions can explain the value completely."
"We didn't get the fifth force, but we did get a very nice and probably the best proof of quantum theory, which is the underlying theory of all our understanding of the most fundamental questions of nature," Fodor said.
