What did you build today ?
Externet
Joined Nov 29, 2005
2,678
Greetings.
Decades ago had difficulty probing with the oscilloscope and multimeters, the tiny leads in shrinking chips.
Made my own probe for use at the workplace, and today; found one behind the spider webs. Several others I made went to technician fellows at work that begged for them. Decided to make another now.
It consists of a thin sewing needle pushed into the ink-side of a ball pen tip, ejecting the ball and force-locked in. The cable used was Belden 9221-75 Ohms soldered, the shield only connected at the oscilloscope; the DUT grounded separately. We worked troubleshooting audio.
Image 1 : a ball point pen, discarded the ink tube, pushed the ball out with a needle, inserting a sewing needle in the tip and soldered to the coaxial center. The shield end just a couple of millimeters short of the tip. I used Belden 9221-75Ω . Secured in the pen body to not stress the soldered end. Can be messy if not careful to avoid ink spills.
Image 2; hard to see is the sharp needle protruding 2mm. Does pierce any tiniest place without sliding/shorting another, extremely comfortable and precise to handle. Felt to share this with you.
[Perhaps someone can trick image 2 to make it more discernible, the needle shows 2mm.]
BobTPH
Joined Jun 5, 2013
11,662
I recently acquired this tea infuser (for loose tea) to be used right in the mug.
Three problem:
1. The slightest bump and it falls into the mug.
2. It gets hot to touch.
3. The handles are too short to grab it easily.
I put on my 3D printer hat and came up with this:
I first made it with ABS. On first use, it turned into a parabola. Who knew that thermoplastic with a melting point of over 200C would soften so much at less than 100C?
Doing a little research, I learned about annealing. This does not work for ABS, so I went to PLA, which softens even worse without annealing. I printed it, put it in the oven at about 95C for 1/2 hour, then let it completely cool without opening the oven.
Now it can stand the temperature, but the process shrinks it, so I had to adjust the size to account for the shrinkage. Been using it for a couple of weeks now, with no softening. Life is good.
28,424
Yesterday I tried to make it work. Not quite the same as building it, an OLD 146 MHZ transceiver. Not much progress.
The build project was replacing the tiny compressor on a small portable compressed air system. a 3/4 inch bore with a 1 inch stroke will not pump much air. Replacing that with a small refrigeration compressor sealed unit. Much more air flow and much quieter. But a serious mounting challenge.
Externet
Joined Nov 29, 2005
2,678
Removed the guts in old compact fluorescent bulbs and connected the bases to 50 Watt LED wafers. That is brutal bright ! :oops:
