Kindly suggest the changes i hv to do for replacing IRF540 for 2N3055.
Now the circuit makes a bit more sense.Sorry!
There was schematics mistake. The 2N 3055 was not proper in diagram.
Here is the one which is proper.
Do u think it will be better to use Mosfet?hgmjr :
The trick in converting over to mosfets will be to supply the mosfets with the voltage level needed to turn them on under just the right conditions to protect the speakers from overdrive.
by Don Wilcher
