You need to clarify what you are trying to do -- specifically, what is meant by "middle value".I was writing one program in that i want to find the middle value in an array.so can anyone tell me how to find that value in labview or which function i should use?
There is no point throwing a bunch of LabView code together unless you understand the problem you are trying to solve.Build a VI that first accumulates an array of temperature values
.the array size is determined by
a control on the front panel. Initialize an array, using the Initialize
Array function, of the same size where all the values are equal to 10.
Then add the two arrays, calculate the size of the final array, and
extract the middle value from the final array. Display the
Temperature Array, the Initialized Array, the Final Array, and the
Mid Value.
in this for mid value which function i should use or how can i resolve that?
