I'm not sure if this goes in the digital or analog section, so please forgive me if I chose poorly.
I have an FPGA that is an HDMI source. The design is working fine while everything is powered on. However, when I power down the FPGA board with the monitor still powered, the pull-up resistors in the TMDS sink (the monitor) back-drive into the FPGA and cause it to go into a quasi-powered state.
Apparently this is not uncommon, and there are buffer ICs and such. So I'm looking into a few options and I have found a chip that looks like what I need, the TPD12S016 (http://www.ti.com/lit/ds/symlink/tpd12s016.pdf)
The datasheet says it provides "Back-drive Protection on HDMI Connector Side Ports", "ESD protection", etc. What is unclear to me is if the back-drive "protection" is for the device itself, i.e. meaning the TPD12S016 will not provide a path for back-drive currents, or it the device is providing back-drive protection for the source transmitter that it is connected to (which means it would provide a path for those currents to keep them out of the transmitter)?
The connection to the TPD12S016 is a single point for each of the TMDS signals and the functional circuit from the datasheet is attached.
Thanks,
Matthew
Thanks,
Matthew
