TLV1811 comparator setting into push pull mode
yef smith
Joined Aug 2, 2020
1,479
yef smith
Joined Aug 2, 2020
1,479
Hello, When I want to choose TLV1811 component I have difference of the last letters in the name.
I have DCKR and DBVR.
What is the difference between them regarding footprint sctructure?
Thanks.
In the data sheet they say DBV and DCK are the same footrpint but they dont mention the last letter "R"
BobTPH
Joined Jun 5, 2013
11,647
Mistakes happen. Feel lucky you caught it now. Don’t know Altium, so I cant’t help you fix it. But I would create my own part instead of fixing their’s because an update risks having your fix overridden.
schmitt trigger
Joined Jul 12, 2010
2,229
I echo Bob’s comments. You are lucky that you caught the error now, and not after you have assembled the components, powered up the unit, only to find that it is misbehaving.
Ask me how I know.
Nowadays, when you select a component, make sure that you are using all letters and numbers to select the correct package and pin configuration.
