Tips for Optimizing Analog Circuit Designs for Noise Reduction
krutibhinde
Joined Jan 24, 2025
Nothing’s more frustrating than building an analog circuit and getting unexpected noise messing with your signals. Whether it's hum, interference, or random glitches, noise can be a real headache. Here are some practical tips to keep it under control:
Keep Your Grounding Clean – A poor grounding strategy is a common noise culprit. Use a single-point ground (star grounding) where possible and avoid ground loops that introduce unwanted signals.
Shorter, Shielded, and Twisted Wires – Long traces act like antennas, picking up interference. Keep signal paths short, use twisted pairs for differential signals, and shield sensitive lines.
Decoupling Capacitors Are Your Best Friend – Placing small capacitors (like 0.1µF or 1µF) close to power pins helps filter out high-frequency noise and stabilize voltage.
Separate Analog and Digital Grounds – Mixing them can introduce digital switching noise into sensitive analog circuits. If they must connect, do so at a single strategic point.
Use Low-Noise Components – Not all op-amps, resistors, and transistors are created equal. Choose low-noise versions when working with precision circuits.
Filter Out the Junk – Adding low-pass filters can help remove unwanted high-frequency interference before it messes with your signals.
Keep High-Current Traces Away from Sensitive Signals – Power traces and switching components can couple noise into analog paths. Good layout design is key!
How do you deal with noise in your analog circuits? Any go-to techniques or lessons learned the hard way? Please tell me in comments.
Don’t use high value resistors for biasing, bias hard. If not possible the traces to them should be very short and longer the low impedance traces rather. High impedance traces shouldn’t cross the low impedance noisy traces.
Use shielding.
Use toroidal cores for inductors if possible, they produce much less noise.
35,299
Assuming that this is entirely an analog circuit and you have done everything suggested by ChatGPT, you are possibly still encountering two types of noise, (1) line frequency noise and (2) thermal noise. You can try operating outdoors using batteries and lowering the temperature.
28,595
One detail not mentioned is "ground". That really should be a separate circuit, the power supply common. That green wire safety "ground" connection can have all sorts of noise voltages present from different sources.
The good news is that there is a whole lot of published information on avoiding noise pickup.
