Timers- Calculating Time period [SOLVED]
Pushkar1
Joined Apr 5, 2021
416
I understand a few things about timers in microcontrollers but I still don't fully understand timers. I would really appreciate any help understanding timers. I have spent about four to five hours on the internet to fully understand timers but still i am not getting things clearly.
Till now I understood that any microcontroller has a timer which is used to get the specific time. For example, if 12 ms is required, so timer can be configured for it.Timers can be of different size e.g. 8 bit timer, 16 bit time and 32 bit timer. Timer model has timer control register and timer register that also need to be configured
I am trying to understand how the specific time calculated for a timer. So what are main points we should remember to calculate any time period?
Does it make sense to calculate the time period?
Timer Mode : 8 bit timer
Clock Source : 5 MHz
Pre-scaler : 1/4
auto-reload : Yes
Timer Start : 100
How much specific time it will get?
ericgibbs
Joined Jan 29, 2010
21,509
hi P,
What do you make the Timer0 rollover interval, [ FF > 00 ]with those settings.?
E
Update:
Or what number of internal Timer 'counts' will be required to roll over.??
Pushkar1
Joined Apr 5, 2021
416
Update:
A basic 8-bit timer will start from 0 to 255. This will rollover from 0 to 255. I would preset the timer to 100. It will start at 100. It will rollover to 255.
256 - 100 = 156 Timer will repeat every 156 times without Prescale.
This is my understanding, will it happen
ericgibbs
Joined Jan 29, 2010
21,509
Hi P,
Sounds close enough.:)
Are you sure about this : will repeat every 156 times
Next point Clock Source : 5 MHz
Which clock does this refer too.?
E
Hint: ref repeat.
C:
[CODE=clike]void interrupt(){      //This function is called on each interrupt
   if (TMR0IF_bit) {   //Check if Timer0 has caused the interrupt
      LATB = ~LATB;    //Toggle PORT to generate square wave
      TMR0IF_bit = 0;         // clear interrupt flag
      TMR0L = 98;             // Preload timer0
Pushkar1
Joined Apr 5, 2021
416
Hi P,
I think so because i choose autoreload option in setting. is something wrong?
So only two options are available in the setting, internal and external clock source. I am assuming that only 5 MHz of internal clocks are being sourced at the input of the timer.
Update :
Timer Mode
: 8 bit timer
Pre-scaler : 1/4
auto-reload : Yes
Timer Start : 100
Clock : Internal clock
ericgibbs
Joined Jan 29, 2010
21,509
hi P.
I was aiming to draw your attention to the requirement that the Timer has to be reloaded, without the 100 count reload, the next count would be 256.
So when using say PIC MCU with a internal Timer0 Clock Source : 5 MHz , what would the MCU clock frequency be.??
E
Update:
What Time period would a single cycle of a frequency of 5,000,000 divide by 4 be.= .....
and what is the total time, if that period if multipled by 156 = .....
Pushkar1
Joined Apr 5, 2021
416
Why only PIC?
I thought if we knew the size of the timer, the prescale value, and the clock source frequency for the timer, we could calculate specific time period. There is know need to clock of particular microcontroller. Am i creating misunderstandings in my mind?
ericgibbs
Joined Jan 29, 2010
21,509
hi P,
It was for your personal information database, a PIC MCU divides the crystal clock by 4, so a 5MHZ internal clock would mean a crystal of 20MHz.
So what is the answer to this part:
Update:
Pushkar1
Joined Apr 5, 2021
416
hi P,
As far as I know, PIC works on CISC architecture whereas ARM works on RISC architecture?
I am trying to understand peripheral of ARM microcontroller. Therefore it would not be beneficial to read the architecture of the pic microcontroller.
May be my question is, what do we need to know to find out the time period? I have already shown some e.g size, prescale, input clock source
ericgibbs
Joined Jan 29, 2010
21,509
OK.
Are you able to answer this.
Update:
and what is the total time, if that period if multiplied by 156 = .
Pushkar1
Joined Apr 5, 2021
416
1 clock period = 1/ input frequency 5 MHz = 0.0000002 us
Divide by 4 Prescale
0.0000002 us / 4 = 0.00000005 us
156 cycle * 0.00000005 = 0.0000078 us
Have I got the correct period?
Pushkar1
Joined Apr 5, 2021
416
hi P,
Try again.
The 4 divider divides the Clock input Freq to the Timer NOT the Period.
I did it
Frequency into the 8 bit timer = 5000000 Hz /4 (prescaler) = 1,250, 000Hz
1 clock period = 1/ 1,250, 000Hz= 8e-7 us
156 cycle * 8e-7 us = 0.000 1248 us
