2 Off-delay timers - 1 Flashing Light
fanner_b
Joined Mar 21, 2018
30
I'm looking for assistance. I've been instructed to design a basic circuit that employs 2 off-delay timers, 1 light and 1 switch. The idea is that upon closing the switch a light will be on for a defined period of time. Once that time has elapsed, the light will be off for a defined period of time. The cycle will automatically continue indefinitely provided the switch remains closed.
I've executed this using 2 on-delay timers. I cannot seem to wrap my head around creating a circuit like this with off-delay timers.
Note: The timers are 11 pin solid state.
I appreciate any advise/help with this.
fanner_b
Joined Mar 21, 2018
30
What timer exactly?
It's an Omron but basically looks like this and behaves in the same way. There's a start switch between pins 2 and 6 that when shorted, will change the positiion of the time delay contacts immediately (because off delay), but once the button is released, the timer will commence.timer.png
fanner_b
Joined Mar 21, 2018
30
Does this one switch need to be connected as a Start switch on terminals 2 and 6?
No. So the one switch powers the circuit.
I'm thinking there may need to be control relays with NO contacts to control the 2-6. I could be wrong but that's what I'm thinking. 2 control relays maybe in total as the are no instantaneous contacts with this sort of timer.
fanner_b
Joined Mar 21, 2018
30
Thanks for the info.
Post how you have it working with the ON delay timers please.
This is what I have for on delay.
I have 2 on delay timers. 1TDR and 2TDR.
As you can see I also shorted 2-6.
The operation is as follows. Switch closes, 1TDR is is energized via 2TDR1. 1TDR1 and 1TDR2 delay changing positions for 9 seconds. After 9 seconds both 1TDRs change and now 2TDR energizes for 5 seconds. After 5 seconds 2TDR1 opens and the circuit restarts
In summary red light on for 9 seconds and off for 5 seconds. Repeats.
sghioto
Joined Dec 31, 2017
8,750
OK. So the challenge is to do that using the timers in the D Mode Signal OFF- delay.
Solution requires using both sets of contacts on both timers.
fanner_b
Joined Mar 21, 2018
30
Ok thank you for the tip. I'm going to go back to the drawing board now to see what I can come up with.
Am I correct in saying that a NO contacts from a control relay will be used to actuate between pin 2 and 6 of the TDRs?
fanner_b
Joined Mar 21, 2018
30
Based on my schematic, I can have the light on for 9 seconds. This is usIng the NO control relay to control the operation of pins 2-6 on the TDRs. However, I cannot seem to figure out how to have the light off for 5 mins before the sequence restarts.
fanner_b
Joined Mar 21, 2018
30
In my setup both timers are activated simultaneously when power is applied.
Edit: I said 5 mins in my last post. I meant 5 secs.
I'm still lost. I know this forum isn't here to provide answers and I'm also not asking for the answer. I'm simply at a stale. If I provide what I have, am I able to get feedback or comments to say if I'm on the correct track or if I'm just out to lunch?
fanner_b
Joined Mar 21, 2018
30
Correct the feedback works both ways.
Well to start I sincerely appreciate your willingness to help!
Here's what I have.
So to start CR is energized which will close 2-6 on both TDRs. This will change the position of all contacts immediately (as per Off delay theory) and then since contact in series with CR opens, this in turn opening 2-6 on both TDRs, the timer starts the light is on for 9 seconds. I think the above is correct.
Now where the 5 seconds off comes in that I cannot figure out. Because if I put 5 seconds on 2TDR for example, then the light won't be on for 9 seconds.
sghioto
Joined Dec 31, 2017
8,750
You have added a relay to the equation, is that allowed?
My solution does not require an additional relay.
Also, how will both Timers get activated if pin 2 is not connected to L1?
fanner_b
Joined Mar 21, 2018
30
Also, how will both Timers get activated if pin 2 is not connected to L2?
I have added a control relay because on these Omron timers between pin 2 and 6 is the start. If I short pin 2 directly to L2, then how do I turn off pin 2 in order to trigger the off delay timer? My understanding of using these timers in D mode (off delay) is that once you short pin 2-6, time delayed contacts change immediately. Only once 2-6 is de-energized afterwards, the timer function starts.
sghioto
Joined Dec 31, 2017
8,750
Correct, but only if the timers have power on pins 2 and 10.
You don't. Hint: Timer2 runs longer then Timer1 for the required OFF time.
Check out how to activate Timers when power is first applied.
